Vararam
Old 10-15-2022, 11:08 AM   #1
pjm333
pjm333's Avatar
Drives: 2013 Camaro ZL1 Convertible
Name of this part ?
Drivers side door, rubber weatherstrip ?? Some of the rubber is missing & I want to replace the whole piece. Thanks
125 JRE 125 RWHP Package
pjm333 is offline   Reply With Quote
Old 10-15-2022, 03:13 PM   #2
Ashen 6.2
Ashen 6.2's Avatar
Drives: 2014 Camaro Z/SS
I think this is it - https://www.gmwholesaledirect.com/oe...Y4LWdhcw%3D%3D
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP
Ashen 6.2 is offline   Reply With Quote
Old 10-15-2022, 04:21 PM   #3
pjm333
pjm333's Avatar
this is the part I needed
That is called the "front side door weatherstrip". Left hand side (driver) GM 22842049 for the 2011-2015
Old 10-16-2022, 07:00 PM   #4
HDRDTD
Make sure you're getting the weatherstrip for the door opening including the door sill and not the weatherstripping for the door itself.
https://www.classicindustries.com/sh.../weatherstrip/
Old 10-17-2022, 01:14 AM   #5
pjm333
pjm333's Avatar
HDRDTD Thanks
Old 10-19-2022, 01:50 PM   #6
ChuckZL1
Drives: Chevy Camaro ZL-1
DAMN that is expensive for rubber
ChuckZL1 is offline   Reply With Quote
Old 10-19-2022, 02:35 PM   #7
pjm333
pjm333's Avatar
I agree, anyone know how to uninstall / install ??
Old 10-19-2022, 08:41 PM   #8
VChula
SoCal C5 Family Member
VChula's Avatar
Drives: 1996 Z28 SS & 2014 ZL1
It simply pulls off after you remove the lower door sill plastic piece - which also pulls out.
You will also need to pull back the edges of the lower front footwell and quarter panel trim pieces to install the new seal pieces.
There also may be a couple of screws or snaps that may have to be released on the convertibles (below the quarter side window).
Vance Chula -
1996 Camaro Z28 SS #1688
2014 Camaro ZL1 Coupe #1956
VChula is offline   Reply With Quote
Old 10-19-2022, 11:18 PM   #9
pjm333
pjm333's Avatar
Thank you !!
Old 10-20-2022, 07:52 AM   #10
Roamer63
Roamer63's Avatar
Drives: 2014 camaro 2ss/rs
Ha, mine looks about the same. It's from dragging your foot as you exit the car. I placed a piece of wide painters' tape over mine. Foot slides over easily.
Roamer63 is offline   Reply With Quote
Old 10-20-2022, 02:27 PM   #11
pjm333
pjm333's Avatar
Great idea, thanks !
