Go Back   CAMARO6 > Technical Camaro Topics > Audio, Video, Bluetooth, Nav, Radar, Electronics
Old 09-20-2017, 04:16 PM   #1
GAHDOOSH
GAHDOOSH
GAHDOOSH's Avatar
Drives: 2016 Camaro 1SS
Angry Hard wiring radar detector to pass. footwell
Spent hours removing the passenger footwell insulator and glove box to find a bunch of harnesses. No easy labeled accessory wire or ground wire.
Thought someone doing footwell lighting would have figured this out already but a google search provided only plug and play GM footwell lighting kit install instructions.
Anyone got a photo of which one of those wires to tap into?
2016 1SS
GAHDOOSH
2016 1SS 6.2L LT1 Manual 6-Speed, Front Emblem Blackout, Rear Bowtie Delete, Side emblem delete, Phastek Side Marker Tint, GM Black Taillights, $23.57 of Premium Gas this morning
GAHDOOSH is offline   Reply With Quote
Old 09-20-2017, 04:27 PM   #2
zeekle
Drives: 2017 Camaro 2SS
well the the area above the mirror is the easiest place to hit if you are just doing a radar
zeekle is offline   Reply With Quote
Old 09-20-2017, 04:42 PM   #3
k818mn1
Drives: 2016 Camaro SS, Garnet Red
Yes, the overhead console is easier to access the wiring. See http://www.camaro6.com/forums/showth...ighlight=radar
Or you could buy a plug and play harness http://www.gen5diy.com/Chevrolet/Cam...arness-220300/
k818mn1 is offline   Reply With Quote
Old 09-20-2017, 08:26 PM   #4
chris227
chris227's Avatar
Drives: 2020 Camaro 2SS
Driver's side under dash where the wiring harnesses are is a easy to reach ground and power. I posted somewhere in here when I did my footwell lighting. But the overhead console is the easiest for radar.
chris227 is offline   Reply With Quote
Old 09-20-2017, 10:39 PM   #5
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
Run a hot wire from the trunk to the front of the dash...
That's what I did.
2017 ZL1 M6 Bog City, 2013 ZL1 M6, 2010 2SS M6
ZL1::J-E-T-S JETS JETS JETS
bobby35ny is offline   Reply With Quote
Old 09-21-2017, 12:34 PM   #6
Childs Play
Pizza & Wings Only $12.99
Childs Play's Avatar
Drives: 2017 Camaro SS
I can't help you with the wiring from a side panel.
But I can vouch for the plug and play harness from gen5diy. Took me 15 minutes maybe to install it and it was simple and straight forward. Completely reversible too if you want to remove it eventually.
H-Town Camaro Club
Past Rides:
2012 Camaro 2SS/RS M6
2012 Camaro ZL1 A6
2017 Camaro 2SS M6
Childs Play is offline   Reply With Quote
accessory, radar, wiring, wiring help
