BeckyD @ James Martin Chevy
Old 05-26-2023, 11:09 AM   #1
Don_Izzo
Don_Izzo's Avatar
Drives: 2017 Camaro SS 1LE
Marks on SS 1LE Rotors
Any of y’all seen these marks on your rotors? I looked around in old threads but couldn’t find a post showing something similar to what I’m seeing. The brakes are not noisy and they work fine, I’m just curious as to what’s making these marks. I do feel a slight vibration at highways speeds, even after getting my tires re-balanced so there might be some rotor warping going in too.
Don_Izzo is offline   Reply With Quote
Old 05-26-2023, 11:11 AM   #2
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
do you track it or just street use? oem rotors and pads?
Old 05-26-2023, 11:21 AM   #3
Don_Izzo
Don_Izzo's Avatar
No, I haven’t tracked the car. I drive it 3 days per week, 12 mile commute to work and some weekend backroad spirited driving (once or twice a month). I bought the car as a certified preowned so I assume it’s all OEM parts.
Old 05-26-2023, 08:09 PM   #4
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
Check the condition of the pads and the thickness. There is a wear tab on the side of the pad. They may need to be replaced. Then I would do the brake pad Brake Burnishing process found in the owners manual.
carguy55 is offline   Reply With Quote
brakes, rotors, ss 1le
