Old 12-14-2013, 09:21 AM   #1
azw131
Team LLT
azw131's Avatar
Drives: 2012 WRX (Stage 2)
Installing Universal Fit Cats with LT Headers?
I'm currently running OBX LT headers with the catless mid pipes, and am thinking of installing Cats in order to pass emissions without trouble. I've found a lot of universal fit cats on Summit racing etc., but am wondering what will work with my set up? I'd assume they'd be welded in place of my catless mid pipes, but this makes it difficult because the header has a 1 3/4 inch tube and I believe the exhaust is 2 or 2.5 inches. Could anybody lend me some insight here?
Mods: Bolt On's and Such, Some Cosmetic Stuff Too
azw131 is offline   Reply With Quote
Old 12-14-2013, 11:57 AM   #2
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
An exhaust shop should be able to do it for you. It's what I'm doing for my pacesetters
Click Picture for Build Thread
lscamaro is offline   Reply With Quote
Old 12-14-2013, 01:23 PM   #3
azw131
Team LLT
azw131's Avatar
My concern is regarding finding one that fits though. All the ones I have seen are the same size on both ends. Which would work if they were to place them behind the midpipes, but wouldnt that cause an issue because of where they are meant to be in relation to the O2 sensors?
Old 12-14-2013, 05:40 PM   #4
camaro4mybday
"Camaro Joe"
camaro4mybday's Avatar
Drives: 2010 SILVER ICE 2LT/RS CAMARO
Send a message via AIM to camaro4mybday
call american racing headers and get a set of there 49 state legal high flow cats. there made for the camaro
camaro4mybday is offline   Reply With Quote
Old 12-14-2013, 06:54 PM   #5
azw131
Team LLT
azw131's Avatar
That would be a good solution, though given the price it doesn't work so well for me.
Old 12-14-2013, 07:05 PM   #6
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
Get the catted pipes from OBX. For the V8 system, I got both of them for $200. That may sound pricey, but they are high flow, polished stainless steel, and will bolt right in place, no modification required, and after inspection, you can just throw your cat-less mid-pipes back on, save these for next inspection.
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
Old 12-14-2013, 09:28 PM   #7
RED10LS
Drives: 2015 Camaro SS/RS Silver
I recomend that you get metal core not ceramic core high flow cats, thats what I have and I have never got a check engine light.
Cai Intake, Pacesetter Ceramic Coated 1 7/8 Long Tube Headers and Legato axel back exhaust.
RED10LS is offline   Reply With Quote
Old 12-15-2013, 09:06 AM   #8
azw131
Team LLT
azw131's Avatar
Will these fit the v6 headers without any modification, and if so, where did you find them. I couldn't find them for sale online
Old 12-15-2013, 12:50 PM   #9
Batmanntexas
I got mine from "RacingPartsDepot.com". I did a quick search, and found this http://www.rsaperformance.com/obxexm...FbA7MgodnXUAvQ
The image shows the cats available along with the off-road pipes. The vendor may be able to sell just the cats. Check it out.
-Scott
COTW 9/8/14
Old 12-15-2013, 07:31 PM   #10
azw131
Team LLT
azw131's Avatar
Thanks! I'll give them a call
Old 12-16-2013, 10:45 AM   #11
stevey_frac
Drives: 2010 LT2/RS Coupe
You also have an IPF tune, according to your sig. The IPF tune stops listening to the rear O2 sensors, I thought...
Mods so far:
MRTv2 Exhaust
275 / 40 / 20 Continental ExtremeContact DW's on all corners
Next up:
Magnaflow Resonated X-Pipe (Purchased but not installed)
EBC Redstuff street pads
Carbotech XP8 / XP12 track pads
1LE Track Pack
Note: This car built by JDP Motorsports!
stevey_frac is offline   Reply With Quote
Old 12-16-2013, 06:20 PM   #12
SteveDoten@ARH
SteveDoten@ARH's Avatar
Drives: 2010 SS, (ARH/Farks 8sec car)
Thanks for the referral
Steve
SteveDoten@ARH is offline   Reply With Quote
Old 12-19-2013, 11:13 PM   #13
RED10LS
When they did the tune I did not tell them to tune out the back 02 sensors.
Old 12-20-2013, 05:06 AM   #14
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
Tuning out the back O2 sensors might be part of their standard practice. IT was that way for Trifecta for a while. But now you have to go in and turn them off yourself, which I can do on my Trifecta tune.
rtcat600man is offline   Reply With Quote
