09-30-2021, 02:11 PM | #15 | |
Drives: 2022 Kia Stinger GT2 Join Date: Oct 2019
Nice thanks I will file those away. Yeah I've heard about OH Route 555 being a good road too. |
09-30-2021, 03:16 PM | #16 | |
The 1LE handles as good or better than most anything out there, in other words, it's world class handling. This has been proven over and over again. There are plenty of "GT" cars out there that have big engines/high HP, but they are not the absolute monster the SS 1LE and ZL1 1LE are in this regard. It is not the lightest car though, so cars like the Cayman and BRZ will be more nimble in short courses. Those are classically good handling cars, but a large part of that is their weight.
10-01-2021, 07:44 AM | #17 | |
Drives: Camaro ZL1, Dodge TRX Join Date: Sep 2021
Also, I respectfully disagree with the OP concerning his reasoning about a momentum car having a too-high corner entry speed. A horsepower car that corners well is tougher and scarier because of the very high speeds approaching the corner, and the requirement to brake hard down to your highest entry speed to enter the corner. You'd be going faster everywhere in the ZL1. If you're determined to drive fast on the public roads, and I do it too, the BRZ will scare you less in the corners because the speeds will be lower approaching the corner, and probably through the corner also. Last edited by Zone5; 10-01-2021 at 08:10 AM. |
10-01-2021, 07:53 AM | #18 | |
Drives: 2023 Chevrolet Camaro 2SS 1LE Join Date: Jan 2020
10-01-2021, 08:30 AM | #19 |
When the 6th Gen Camaro came out in 2016, Motortrend tested it against the same year BMW M4 and found it to be objectively better in every way.
My 2017 2SS (non-1LE) is one of the best handling cars I have ever owned or driven. |
10-01-2021, 09:03 AM | #20 |
Yeah, my point was that a momentum car wasn't scarier in the corners due to the speed required to have momentum. A horsepower car can enter at the same speed as a momentum car can, whether holding the speed between the corners as you do, or approaching at high speed and then braking.
10-01-2021, 11:40 AM | #21 |
Drives: 2019 Camaro 1SS Join Date: Oct 2020
Buy a v8 before they are gone. 1LE is the best overall car out there pound for pound. It can do it all. Hell, even a 1SS or 2SS with the magnetic dampers is pretty awesome. The only very minor downside is if you care about it or not is fit and finish. It could be a little better, but what you get in performance and fun factor makes you not think about it at all. A second choice if you care more for daily usability and saving a couple of bucks then it would be the BRZ. The rest are not bad choices, but with the current market, you will have to buy older to say in the same price range. Just my 2 cents from a 50 year old guy.
10-01-2021, 01:09 PM | #22 |
10-01-2021, 02:21 PM | #23 |
Say f-it and get the Emira
2023 Camaro ZL1 Vert TR-6060 Sharkskin "Sharky"
Firecracker Red Wrangler Willys, 3.6L eTorque, 850RE 8 speed automatic, 25W Willys package, Technology Group, Convenience Group (aka $600 garage door opener), Cold weather Group, Trailer Tow and HD electric group with AUX switches, 3 piece black freedom top. |
10-02-2021, 08:08 AM | #24 |
Drives: 2018 SS 1LE Join Date: Apr 2017
Here's a comparo Motor Trend did a while back when the 6th gen was first released. Full article and video.
https://www.motortrend.com/reviews/c...let-camaro-ss/ |
10-02-2021, 12:58 PM | #25 | |
Hail to the King baby!
Drives: '19 XT4 2.0T & '22 VW Atlas 2.0T Join Date: Dec 2008
They found it "SUBJECTIVELY" better in every way. Objectively the 2 cars tied in every measure except braking distance and the BMW had carbon brakes.
10-04-2021, 08:10 AM | #26 | |
Drives: '16 Camaro SS 6 spd manual transm. Join Date: Aug 2012
BRZ is a great handling car, but it lacks power. Porsche, BMW and C7 Corvettes are very expensive to maintain. The 6th gen Camaro SS would give you great handling and power, and it would be able to beat those cars that you mentioned and its be very close to the Corvette C7's performance. If you are planning to go to the track often you can get a Camaro SS1LE or even go to higher power with the ZL1.
'16 Camaro SS
Prior cars: '14 Corvette C7 Stingray Z51 '14 Camaro ZL1 w/. Recaro seats '11 Mustang GT 5.0 w. track package '02 Porsche 911 Carrera '05 Infiniti G35 coupe sport Last edited by Bosse'sBoss; 10-04-2021 at 08:24 AM. |
10-04-2021, 04:39 PM | #27 | |
Drives: Chevy Camaro LT1, BMW M3 Join Date: Apr 2021
Handling.. Stock for Stock the Camaro is better. It's a newer chassis and feels stiffer and a little more precise. The camaro steering rack is faster, and has good feel for EPS, but the M3 has a bit more road feel with its hydraulic rack. Camaro seems to have sharper turn in. The general balance with both cars is very similar, their wheelbase is with an inch apart and have the feeling of well balanced RWD cars. My LT1 has 245 all seasons so the limits are much lower, which might be a benefit if you want to have fun on public roads. The BMW feels a bit more confidence inspiring because of the much lower torque and higher grip (not the Camaro's fault, unique to my trim level). When it does let go, the BMW feels a bit more progressive and 'easier to catch'. The Diff lockup is more predictable in the BMW. my Camaro does not have an E-diff. I have never driven a Camaro SS with summer tires so I can't comment how proper rubber and a better diff change the car, but I can say the general dynamics of my LT1 are excellent and does not feel 'inferior' to the BMW and is superior in many ways. |
10-04-2021, 07:19 PM | #28 |
Drives: Camaro SS 1LE Join Date: Aug 2018
