02-06-2022, 07:03 PM | #1 |
Drives: '15 Cam Join Date: Feb 2022
New Brembo Brake Pads - Fronts and Rears ('10-'15 Camaro)
Hi everyone! I have a full front and rear set of brand new, never installed Brembo brake pads, and I don't have a use for them. I'd like to find someone who can use them, and get them out of my garage:
These are for Brembo GT 6-piston (front) and 4-piston (rear) systems. The markings on the pads are as follows: Set #1: "Brembo 07.9551.13" ; "FERODO HP 1000":"RACING INSPIRED" Set #2: "Brembo 07.8645.16"; "FERODO FM1000 FFA14"; RACING INSPIRED"; "319" To confirm their application, I e-mailed Brembo, and the following is what they told me about the pads: Front (07.9551.13 Pad Number) pads; Ferodo FM1000 street compound for wide annulus 6-piston“N” system. These pads are used in our “N” calipers, these are 6-piston calipers that are used in conjunction with a wide annulus disc. Standard annulus is roughly 53mm in our GT systems, with wide annulus being 61.5mm. So these pads are designed to account for the additional ~8.5mm of disc surface area. Any of our systems that have “N” as the 2nd character would use this pad shape. Rear (07.8645.16 Pad Number) pads; Ferodo FM1000 street compound for standard annulus4-piston B/H/P systems. These pads are used in most of our 4-piston systems and can be used with 345x28mm – 380x28mm disc assemblies. I do not have the original packaging or the hardware. Asking $300 OBO + shipping (they weigh ~14lbs, if you want to estimate the cost) from NYC metro area. I will not separate - must buy all 8 pads. Last edited by Camaro162; 02-26-2024 at 06:09 AM. Reason: update |
03-08-2022, 06:04 AM | #2 |
^Make an offer (I want these gone...) :-)
11-07-2022, 08:32 AM | #3 |
Drives: F150 Velociraptor Join Date: Nov 2022
Do you still have these? I need the 07.9551.13
11-07-2022, 12:01 PM | #4 |
FYI, I got a PM from berrytega telling me to email partsa33@gmail.com to buy these. I ALMOST paypal'd money but realized I was down a rabbit hole of email here, then here, then send money here via paypal friends and family. Etc.
11-07-2022, 04:02 PM | #5 |
Will any of these work on the Z28 rotor thats been converted to iron via the Giro Disc conversion??
Orange Krush II
11-13-2022, 06:36 PM | #6 |
01-19-2024, 12:05 PM | #7 |
These are still available! ...anybody?
brake pads, brakes, brembo, brembo gt calipers, pads |
