Old 03-22-2022, 09:03 PM   #1
stuck_in_ohio
Drives: 2017 Camaro ZL1
Another ZL1 tire thread
Can anyone compare Nitto 555G2 to the OEM Goodyear F1 tires on a ZL1 in the rain? I only have experience with the 555G2 as I bought my 2017 used. Not impressed with Nitto traction (dry or wet) so if OEM is at least decent in the rain I will go that way. No track days but driven "spirited" lol. I want to be able to safely commute in the rain and not spin in 2nd gear when dry (6mt) and not feel the ass float at high speeds if that's possible? Thanks in advance for any input!
stuck_in_ohio is offline   Reply With Quote
Old 03-22-2022, 09:12 PM   #2
Mac7504
Mac7504's Avatar
Drives: 2003 Monte Carlo SS SLP, 2022 ZL1
Personally, I'd not run the oem Goodyear tires in the rain. They are noted as a summer only tire. I didn't feel safe going 45 on them but this was in 33 degree weather with sleet and some rain.
Just my take.
Mac7504 is offline   Reply With Quote
Old 03-22-2022, 09:18 PM   #3
Vigilante375
Drives: 2018 Camaro ZL1
If you're going to drive in possibly rainy conditions, get a set of Michelin PS4S or Pirelli P Zero tires. I'm on my 2nd set of Pirelli's and they handle very well in dry and wet conditions.
Obviously way better than the stock Goodyears on the rain but way worse than them in the dry.
Vigilante375 is offline   Reply With Quote
Old 03-22-2022, 11:07 PM   #4
JSH
JSH's Avatar
Drives: '20 ZLE
The topic of ZL1 tires has been discussed endlessly here.
I'll assume you refer to the current Goodyear Eagle F1 SuperCar 3R as "OEM." This tire is excellent on hot/dry road courses and streets, but horrendous as an everyday street tire particularly in the wet.
The Michelin Pilot Sport 4S has been arguably the best all-around street tire for 5 or 6 years. It's great on dry and wet streets, but can't or shouldn't be driven below 40F, so it can't be a daily driver tire for you if you commute in Ohio. In addition, it's not designed for either the road course or drag strip.
Depending on your car and driving habits, there are a few other tires like the Nitto DRs that might work for you.
No tire is best for every occasion.
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650.
100+ octanes, no eth, no meth, no N2O.
2/23 - 1031/1004 wheel.
4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes).
2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next.
JSH is offline   Reply With Quote
Old 03-23-2022, 10:36 AM   #5
zxspeedspec
Drives: Faster than yours
Originally Posted by JSH View Post
The Michelin Pilot Sport 4S has been arguably the best all-around street tire for 5 or 6 years. It's great on dry and wet streets, but can't be driven below 40F, so it can't be a daily driver tire for you if you commute. In addition, it's not designed for either the road course or drag strip.
I've abused PS4S for years now and I can 100% say they work even down to 19F. My tires aren't cracked and the traction at 19F is surprisingly good. On top of that I've also run them pretty aggressively on the track. Granted that was all in different C7, but even the Z06 on PS4S was good for sub 1:26 laps around SoW.
For about 99.9% of the Camaro population, PS4S is the right tire for any and all situations. Once you get to welding in a half cage and replacing your stock seats with a Sparco carbon bucket, you'll then know enough to choose your own tire.
zxspeedspec is offline   Reply With Quote
Old 03-23-2022, 10:41 AM   #6
JSH
JSH's Avatar
Drives: '20 ZLE
I was referring to Michelin's disclaimer/warning about driving it below their recommended 40F. I too have driven mine in the 30s on sunny afternoons with some road heat.
I was at Bandimere's fuel station [a very flat area] recently with 3/4 inches of snow on the ground, and the only way it would move forward was in idle. These tires spun with a touch of the throttle.
'20 ZL1 1LE A10,
Old 03-23-2022, 11:50 AM   #7
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
Drove mine home new 4 hours from the dealer in pouring rain. Goodyears performed pretty well. After they got to about 3000 miles I avoided driving it in the rain. I just replaced them at 9300 miles with PS4S. Like stated, the Goodyears are an excellent track/dry street tire. Totally suck in the wet unless brand new.
Old 03-23-2022, 02:19 PM   #8
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
My experience with the SC3 is that it's not wet that was a problem it's hydroplaning and it does it very easily, it was to me more about heavy rain, standing water, and puddles that made it dangerous. And over about 40mph in those conditions it will try to kill you quite easily.
WhiteMale is offline   Reply With Quote
Old 03-23-2022, 05:40 PM   #9
Heartbreaker
Heartbreaker's Avatar
Drives: 2020 Camaro ZL-1 1LE
good advice
+1
Home Track: NCM Motorsports Park
Heartbreaker is offline   Reply With Quote
