03-19-2019, 09:22 AM | #1 |
Drives: Garnet Red / ZL1 1LE Join Date: Apr 2016
ZL1 1LE and Brake Fluid
All,
Considering the 'track biased' nature of the ZLE...does it come with DOT4 Brake Fluid from the factory? Just wondering because I don't want to buy a DOT4 fluid and swap if unnecessary. |
03-19-2019, 09:42 AM | #2 |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
Think about this. It's built in Lansing along with the rest of the Camaro line, Cadillac ATS and CTS, all of which are street cars. Whatever bulk barrel of brake fluid that's from the lowest bidder that happens to meet DOT 3 is what's going in the factory fill. It also says in the Owners Manual and the brake fluid cap that OEM is DOT-3.
Make no mistake, the ZL1 1LE is a street car first and foremost. Any pretense about trackability comes down to you doing a competent preparation per the Performance Supplement and Track Preparation guide, the latter which explicitly states they recommend changing the brake fluid to DOT-4. Your job as an entrant to a track day is to follow the car prep rules laid out in the club's vehicle inspection guide. Every single club worth their insurance policy includes verbiage for a fresh brake fluid flush.
03-19-2019, 09:59 AM | #3 |
Drives: Fastish Join Date: Jan 2019
Stock fluid is garbage for track use. GM even says so in their track supplement. Buy Castrol SRF, change once a year. Your car will thank you.
03-19-2019, 10:42 AM | #4 |
Drives: 2018 ZL1 1LE Join Date: Nov 2017
Get the stock fluid out of the car before you even consider tracking the car, I "flushed" mine and obviously didn't get all of it since I boiled mine at COTA this last weekend and it very nearly ended up being a really bad situation. One of the worst feelings I've ever had was a foot full of floorboard going into 12...
2018 ZL1 1LE
03-19-2019, 10:59 AM | #5 |
How many Liters of SRF do you reckon will be required for a brake fluid flush?
03-19-2019, 11:20 AM | #6 |
Just 1
03-19-2019, 12:49 PM | #7 |
Drives: 2018 Hyper Blue ZL1 1LE Join Date: Dec 2018
I prefer Motul RBF 660. A little pricey but great stuff.
Dont use just any DOT 4, many lower priced DOT 4 will boil almost as fast, maybe faster, than stock fuid. e.g. regular Castrol DOT 4 is inadequate, get the Castrol SRF for sure. |
03-19-2019, 12:59 PM | #8 | |
Drives: 1992 Z28 1LE; 2015 Zl1 Join Date: Mar 2009
Still seems like they could go ahead and put DOT4 in the track focused cars and just change the recommended maintenance to match, but I suppose they don't want the confusion for the average dealer who may never see one.
1989 Camaro RS convertible- Sold
1999 Camaro SS - Stolen 2x 1991 Camaro Z28- 1991 Camaro Z28 1LE- 1992 Camaro Z28 1LE- 25th anniversary 2015 Camaro ZL1 |
03-19-2019, 01:33 PM | #9 | |
03-19-2019, 01:47 PM | #10 |
But it’s still not good enough for track use
Srf is the right answer |
03-19-2019, 01:48 PM | #11 |
03-19-2019, 02:37 PM | #12 |
Hot Dog
So does the Hyundai Veloster N. Point still stands that if you're attending track days, a brake fluid flush is part of your prep. What came from the factory is just a placeholder until you prep the car.
03-19-2019, 03:14 PM | #13 |
Drives: 2019 ZL-1, Shadow Gray, Sold Join Date: Jan 2019
Castrol SRF...….I change mine in the Spring, before track season and it lasts entire year, without a problem. Little expensive, but it has one of the highest wet/dry points.
03-19-2019, 08:29 PM | #14 |
Drives: Gen V Viper GTS Join Date: Jan 2018
This! Others need changing but Castrol SRF seems to last a good period (1 year for me at least).
