06-03-2021, 08:20 PM | #1 |
USA-1
Will I get more MPG with cam?
I know, I know, am I serious???
Yes! Right now my commute is about 20 miles or so and I am averaging 18.3 mpg. I drive roughly 90% highway, 10% city, BUT, I'll be moving near the end of this year and doubling my commute to 44 miles EACH way. I've been looking at some threads on here from the past decade or so and seen that some people have actually reported an increase in MPG on the highway after a cam, so if that's the case I 'might' be able to justify a cam swap...LOLOL This sounds crazy to me, but I figured I'd have to ask.
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete |
06-03-2021, 08:27 PM | #2 |
Drives: 2011 Camaro SS Join Date: Jul 2019
No....but I dont find it uses alot more fuel then before.
EPS CUSTOM GRIND CAM....K@N CAI....VMAX PTB.....FRANKENSTEIN STAGE 2 HEADS ...1 7/8 STAINLESS POWER CATTED LONGTUBE HEADERS...CORSA XTREME 3 INCH CATBACK.....CIRCLE D 3800 Pro Series stall...391 gears.....Ported/modded GPI intake .Forgestar drag pack with Mickey Thompson ET street drag radials AGP PERFORMANCE DYNO TUNED. 463 WHP 428 FTLBS TORQUE.
06-03-2021, 08:41 PM | #3 |
You will likely lose MPG. But not due to inefficiencies of the cam profile. Instead, due to your foot magically getting heavier after having a cam installed.
The same thing happens when someone gets a louder exhaust installed.
06-03-2021, 08:55 PM | #4 | |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
But, on the flip side. Mine went up with a really good dyno tune. I tend to keep my foot out of it most times. Also, depends on cam size. Just depends.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
06-03-2021, 09:26 PM | #5 |
Drives: 2010 Camaro SS Join Date: Oct 2020
Just got done upgrading cam and heads. When I WOT I'm pretty sure I can actually see the fuel guage move
Sent from my SM-F916U using Tapatalk |
06-03-2021, 11:44 PM | #6 |
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled Join Date: Jun 2019
MPG's be dammed i rock a SS claiming 400ish hp and run 93. imo if you want better mpg get a economy car.
06-04-2021, 03:04 AM | #7 |
Drives: Ashen grey, 1SS, L99 Join Date: Aug 2016
After my heads cam got installed, with the 3.91s mind you, I got 19.4 averaging 70 mph coming back from liberal, Kansas where I had the car modified. About a 300 mile journey. I was super impressed as I thought I would get terrible fuel mileage. I’m sorry for the blurry photo, but yep 19.4. 73,773 miles and I remember changing it at 74,500 to look for metal shavings.
Roto-fab CAI, Nick Williams 102mm TB, LOD X1 V3 intake manifold, GMPP LS3 heads, Night Fury cam, TSP 2” long tubes, Corsa ZL-1 catback, Nitrous Outlet 102mm plate kit/150 shot, NGK BR7EF plugs with Taylor plug wires, DSX flex fuel kit, ZL-1 fuel pump and injectors, B&M deep trans pan, Yank 3400 converter, 3.45s with BMR Delrin bushings, mishimoto 169° Thermostat, GM ground effects, T-Rex upper grill, Z/28 Spoiler, Lolly pop Lime brake calipers, ZL1 10 spoke wheels, 12” subwoofer, and custom paint matched interior.
06-04-2021, 04:27 AM | #8 |
I can average about 20-21 mpg @ 70 mph on the highway with my set up 22 mpg @ 60 mph.
06-04-2021, 06:21 AM | #9 |
Started#gottalovethatblue
My highway mileage post cam dropped about 1 mpg to 23.5, when I'm strictly only on the highway. My in city mileage went to hell. Just plan on spending more on fuel because it's going to happen. If for no other reason your mileage will go down because you like the extra acceleration.
06-04-2021, 06:27 AM | #10 |
Drives: 2010 SS L99 Join Date: Sep 2018
Mine went down in the city. What cam are you thinking? GPI SS2? You've been overdue for a cam upgrade! happy modding
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E Build thread - www.camaro5.com/forums/showthread.php?t=555371 |
06-04-2021, 06:52 AM | #11 |
Try throwing a blower on as well. Every time I drive now I come back a 1/4 tank down lol. And thats not driving very far. Pretty sure I get like 1 mpg now haha
06-04-2021, 06:53 AM | #12 |
USA-1
Ya, the SS2 VVT...
Looks like I'm gonna have to get another higher mpg car for the commute...kinda expected that, LOL
06-04-2021, 07:02 AM | #13 |
Getting closer to GPM (gallons per mile) territory huh?
06-04-2021, 08:34 AM | #14 |
Drives: 2012 Victory Red LFX Join Date: Dec 2012
Just get a daily and park the Camaro. Did a 500 plus mile round trip in my wifes '19 Kia last weekend. Four adults plus luggage and got 42 mpg at a steady 80mph (because its west Texas.)
Thread Tools | |
