12-07-2019, 08:38 AM | #1 |
Drives: 2018 2SS Camaro Join Date: Jul 2019
Changing Brake Calipers
Hello,
Sorry if this question seems stupid, but you never know unless you ask and I would rather be sure! lol I have a 2017 2LT RS, with stock 4 piston calipers that came with the car. I have a friend who is willing to give me a set of...50th Anniversary Front Calipers for my car. They came off a 2LT with the 50th Anniversary package. I really like the orange calipers and think they would look good on my camaro. Anyone know if they will fit/switch out, OK? What else would be needed? I tried calling 2 local dealerships but they were more confused than I am! LOL I cannot see how they would be that different just need to make sure before going through all the steps and it not work. Thank you in advance.
Let the Good Times...Roll!
12-07-2019, 10:30 AM | #2 |
Drives: 2016 SS Convertible Join Date: Sep 2016
borrow the calipers - take a wheel off and take a look for yourself - do they look the same?
12-07-2019, 12:41 PM | #3 | |
Not Doable...Thanks though 1. Calipers need to be shipped to me. 2. Winter here in New England and snow all over ground, no garage. lol 3. Car in storage 4. Disabled Veteran and do not have the physical capabilties to tackle something like this. Why I was hoping someone could help me, so I would not have to take it to a dealer and have to pay for labor and it not work....If not...no problem...Never know unless you ask! Thanks again!
12-07-2019, 12:55 PM | #4 |
While I can't give a surefire answer, though they should be the same (IIRC the 50th anniversary edition had the RS wheels, tires and brakes), I do want to thank you for your service, Sir.
Hope someone will be able to help you out with the swap.
12-07-2019, 01:25 PM | #5 | |
Drives: 2016 2SS BLK A8 Vert Join Date: Dec 2017
NPP, MRC, Tinted side & rear reflectors, OEM ZL1 Rockers / 3rd Brake / Darken tail lights, OEM Blk rear splash guards, Satin hood wrap, Fuse pull, Sound tube delete, Cat delete, Ported 95 TB, Ported MSD IM, Dry RotoFab, ARH 1 7/8 headers, E85, "Performance Dyno" Tune, BMR "pieces", "Track" alignment, Hawk DCT-70/70's w/SRF, Goodridge lines, Ti shims, Red powdered calipers, 18" APEX SM-10's w/ Pirelli DH's, FE4 Vert swaybars, Brake cooling ducts, ATI 10% UD, Vorshlag camber plates, OEM 1LE Splitter w/APR Ext., Velossa BIG MOUTH Ram Air, CF QA1, ZLE brakes(F)
12-07-2019, 03:45 PM | #6 |
Drives: 2018 1SS 1LE & 1973 Datsun 240Z Join Date: Sep 2015
I gather you have the Heavy Duty Cooling and Brake package if you have the black Brembo 4 piston calipers up front? If so, then judging by the looks and specs, they should be the same...
Brembo 4 piston caliper - black: https://www.apcautotech.com/part-det...t&model=camaro Brembo 4 piston caliper - 50th Anniversary: https://www.apcautotech.com/part-det...t&model=camaro |
12-07-2019, 07:07 PM | #7 | |||
Thank you arpad_m...I appreciate the reply and I feel the same... I cant see why they wouldn't work, with both being 2LTs with 20" wheels. Your Welcome and it was an "Honor" to serve, Thank you! Quote:
I am in the Twilight Zone of New England! lol I am in actually in Maine. I am not sure either, as the part numbers do not match any searches. Even when I called the dealerships they didn't recognize the numbers... BUT... They are out there, for sale but with different part numbers from AC Delco @ $300+ each! They look the same but who knows if they are the same. lol I appreciate your offer to help and if I decide to go ahead and get them, I may take you up on that offer! Where are you in MA? I know MA very well, in my younger days I used to drive Tractor-Trailer, and deliver groceries to the local Stop & Shops, Big Y and other grocery stores. I don't get down there much anymore, as my...EXE lives there and I don't like being anywhere near her! LOL Thanks for your reply and offer! Quote:
I don't think mine are Black...I cannot see or look at them, as its in storage, but I believe they are gray...I may be wrong. But even if just stock 4 piston Brembo calipers are on it...it seems any 2LTs with the RS package would have the same specs and whatnot as a 2LT RS 50th Anniversary. I mean it is only a trim package. correct? I was hoping someone in the...Club Fifty...would chime in. Unless they all have an SS! LOL I really appreciate all your help and replies, I would really like to know for sure one way or another but may have to just take a leap of faith and try!
12-07-2019, 08:02 PM | #8 | |
12-07-2019, 09:25 PM | #9 | |
The RS package does not include the 4 piston Brembo's. You have to add the Heavy Duty Cooling and Brake package option to the RS package separately to get them (however, you can't get the Brembo's without the RS package). If you have the window sticker, that should tell you which options came with the car if you can't visually check right now. If you do not have the Brembo package, all is not lost. You should still be able to swap to the Brembo's but you will also need new rotors. The single piston calipers use a 12.6" rotor. The 4 piston Brembo calipers use a 13.6" rotor. You will of course also need pads/hardware if they don't come with the calipers. Keep in mind, I'm going by catalog info, not hands-on experience with these parts. Nigel |
12-07-2019, 09:47 PM | #10 | |
Drives: '17 2LT/RS 2.0T M6 50th Anniv Vert Join Date: Feb 2019
I own a 2017 F1FTY 2.0T and all of the I4 and V6 (50th Anniversary models) are 2LTs with the RS Package. According to the brochure they are 4-piston Brembos. I do not have the heavy duty braking and cooling (I have the build sheet on an e-mail but I cannot access as my e-mails were hacked. Once I get access I can double confirm). Sorry, I can't be more help and can't stop by to discuss as I'm on the West Coast Good Luck! |
12-07-2019, 09:59 PM | #11 | |
Nigel |
12-07-2019, 10:14 PM | #12 |
Yes...you are correct and it's noted in the 2017 Brochure. I should have looked at the brake options before posting up earlier
12-08-2019, 11:38 AM | #13 | |
Thank you all for your replies and Information, I really Appreciate all your help!
I am the second owner of this car, and the RPO code list was not on the trunk lid, so I have no idea, if it actually has HD Brakes/Cooling. I am going to call a dealership tomorrow and see if I can get a list for my car...I already emailed GM to try and get one. I cannot physically get to the car to look and see what calipers I have on it. I only had it about 6 weeks, before I had to put it in storage. I honestly didn't pay attention to the calipers, because the brakes are/were great! lol I just want to dress her up and make her mine. I am very confused about one thing... I have a... My Chevrolet... account and APP... Under the Performance Tab...You can buy a 6 Piston Brembo Kit ( @ $3100! tho) with bigger rotors and pads, that can go on my Camaro. If that is the case, why wont a 4 piston Brembo system work? Kind of makes you go...Hmmm?! lol No thanks are needed, it was an "Honor" to serve! That being said... I do, Appreciate your...Thanks! Quote:
Been thru there, many a times! I will do that sir! Once again, I appreciate your offer! We already are kindred spirits...both have Camaros, we Love, and both have Exes, and do not like them! Thanks again for everyones help, replies and information. I love my car but if I cannot upgrade it to make it mine, she may have to go and I will know what to look for, next time!
12-08-2019, 12:37 PM | #14 | |
Nigel |
