Vararam
Old 02-05-2024, 11:42 PM   #1
DLG2013
DLG2013's Avatar
Drives: 2013 Camaro LT2 Convertible
Top Limit Switch? Synchronizer? Top No Opening Correctly
I have a 2013 LT2 convertible and my battery died. Immediately after replacing it the top started acting peculiar. When I press the button to open it the "stop beep" sounds and the top stops moving after a second or two. I have to bump the close button then press open again to get the top moving. It beeps and runs a second or two then stops again. It does the same thing when I close it. Beeps and stops. Beeps and stops. I did a search and saw the recommendations of lubricating the hinges and such but I don't think that's my problem. The motion is fine when it's moving but the beep as soon as I press the button seems to be related to the issue. Is there a limit switch somewhere that may be out of whack or bad? Thank you.
Oh! First Post!
DLG2013 is offline   Reply With Quote
