09-28-2023, 09:39 PM | #1 |
Drives: Camaro ss 2010 / Caprice 2013 Join Date: Jul 2023
I need a help SS LS3 overheat
Hey y’all, so I recently replaced the thermostat to MotoRad, coolant temp sensor, and the coolant, The fans work great. So basically my car overheat after a ride when i shut it off for 5 minutes or longer it goes above 221Celsius and some times go above 221, wont start as usual and goes into safety mode the service StabilityTrak notification in the cluster, won’t crank like when it’s cold or at operating temperature, any thoughts cause I’m frustrated and confused?
Camaro ss LS3 2010 Operating temperature/// 178~208 |
09-28-2023, 09:52 PM | #2 |
221 degrees Celsius is 430 degrees Fahrenheit.
09-29-2023, 01:42 AM | #3 |
1000hp is NEVER Enough!
So what is the engine temp. when driving? Did you burp all the air out of the coolant system? Are you running 50/50 mix coolant? Has any type of leak fix been added to coolant? Has the coolant added always been dex-cool? Some coolants mixed with dex-cool turn into gel! Do you have headers? could be heat soak. Also if temps rise when engine running and car parked it is probably your water pump (impeller) issue. Stock thermostats start to open @ 195 degrees. @ 221 degrees f. car should start and run fine, it maybe a different issue. Have any of your ground wires been loosened if yes, check them.
1,000hp IS NEVER ENOUGH!!!
09-29-2023, 05:30 AM | #4 |
09-29-2023, 05:39 AM | #5 | |
09-29-2023, 09:46 AM | #6 |
Drives: 2002 Camaro SS SOM; 2015 Malibu LTZ Join Date: Dec 2010
Check for air in your coolant system. Coolant has to be replaced under pressure to assure that air won't get into the system. Air in the system is a common cause for overheating.
'08 TBSS AWD Black Granite Metallic '15 Malibu LTZ 2LZ Turbo '14 CAMARO ZL1 Blue Ray Metallic |
09-29-2023, 06:16 PM | #7 |
Stock setting doesn’t have fans cut on until much higher than you expect, low is something like the 221 you are seeing and high is about 227. I started troubleshooting mine the first time mine got into that range, but it’s how it’s designed.
09-30-2023, 12:06 AM | #8 |
221 F is 105 C,it is normal.
Hot start issue : battery,ground,starter. |
10-01-2023, 09:19 AM | #9 |
10-01-2023, 09:23 AM | #10 |
It don’t come easy.
What shape is the battery in?
10-01-2023, 01:09 PM | #11 |
12-02-2023, 07:51 AM | #12 | |
EMT NY
Drives: 2011 Chevy Camaro SS White Join Date: Nov 2023
Sensor
Sean |
12-04-2023, 01:14 AM | #13 |
I'm with you on this one. Get the battery tested before doing anything else. And sometimes when they check the battery and say it's good it still can be bad. If it's more than like three years old, you might just want to replace it. Also, one more thing to do is add the extra grounds in the trunk and the chassis.
12-04-2023, 12:14 PM | #14 | |
#ls3, advice or opinions, help me, overheat, problems |
