04-22-2022, 06:42 PM | #1 |
Drives: 2012 2ssrs giovanna edition (japan) Join Date: Mar 2022
Recalibrating speedometer
Hi guys,
My Speedo on my 2011 ss is reading well off and I need to recalibrate it. Before I brought it it was on 22” wheels but I’m not sure the tyre size. It now reads 113km when sitting at 100 so am thinking it’s been recalibrated for the 22” wheels but it’s now on factory size. What’s a scan tool that will allow this change? Not wanting anything too flash as it’s already getting a dyno tune in a week so won’t be used for tuning. Thanks |
04-22-2022, 07:19 PM | #2 |
Drives: 2015 Z/22 Join Date: Aug 2015
Your tuner will be able to address the issue during the tune
Overkill/Self Tuned; Mace Camshafts; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
04-22-2022, 08:30 PM | #3 | |
YouTube-Car Nation Videos
Drives: 2010 Chevrolet Camaro Join Date: Nov 2019
I would try disconnecting the battery completely for about 30 mins. |
04-23-2022, 05:42 PM | #4 |
04-24-2022, 09:26 AM | #5 |
Drives: 2SS/RS Join Date: Sep 2008
04-24-2022, 11:28 AM | #6 |
With handheld tuners (Hypertech,Diablosport,Edge etc.) or HPTuners,EFILive.
04-24-2022, 08:40 PM | #7 |
Drives: 2010 2SS/RS Join Date: Feb 2020
Call your local GM dealer, set an appointment to have them flash the speedo.
