04-06-2022, 10:30 AM | #1 |
Drives: 2012 2LS Join Date: Apr 2021
Finding Electric Cutouts
Good morning, I was wondering if any of you could help me find a good pair of electric cutouts for my 2012 2LS. Reason being I plan on getting my catalytic converters removed next month. However, I don't want to disturb the people in my town. So I decided to invest in some cutouts so I can have the best of both worlds. Will any of you be able to help me?
(Sharing your tips and information you think I don't know about this is encouraged) |
04-06-2022, 10:45 AM | #2 |
Open exhaust on a V6 isn't going to sound good, only loud.
04-06-2022, 10:56 AM | #3 |
04-06-2022, 11:40 AM | #4 |
Drives: 2010 Camaro LS-M6 67 Chevelle Wgn Join Date: May 2009
Go to YouTube and search "v6 camaro open exhaust". That`s what I did when I got my v6 Camaro and decided after listening to quite a few videos that leaving the exhaust stock was less annoying, but it`s your car and if you find a decent sounding exhaust be sure to let us v6 owners know!
Free Trade is not Fair Trade
I am, we are INDIVISIBLE Invictus, By William Ernest Henley |
04-06-2022, 12:46 PM | #5 |
Drives: 2015 Z/22 Join Date: Aug 2015
After installing high-flow cats from Solo my exhaust didn't get too much louder - maybe slightly on a cold start but not much. I suspect cat-less wouldn't be much louder than high-flow, but can't say for sure.
Also have the Solo cat-back and think it sounds pretty good. Based on what I've heard in person I'd say its sound is comparable to a Nissan/Infiniti V6 (G35/G37, 350Z/370Z, etc.).
Overkill/Self Tuned; Mace Camshafts; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
04-06-2022, 04:38 PM | #6 | |
04-06-2022, 05:29 PM | #7 |
Drives: Car Join Date: Jan 2013
Which begs the question….what do you think cutouts do? If I’m reading correctly, if your exhaust is going to be loud with the cats removed, cutouts won’t make it quiet. You’ll have loud and louder. The only way to get from mild to wild is to keep the exhaust quiet then when you open the cutouts it sounds like (and basically is) straight pipes..in the case of a v/6 it’ll sound like an old pulpwood truck.
04-06-2022, 05:48 PM | #8 |
Drives: 2010 2SS/RS Join Date: Feb 2020
There is a difference between loud and annoying.
04-06-2022, 07:09 PM | #9 | |
04-06-2022, 07:18 PM | #10 | |
04-06-2022, 07:27 PM | #11 |
I’m not sure you understand what cut outs do, especially in an aftermarket/modified setup. If you have mufflers, cut outs will allow the exhaust to exit prior to the mufflers. Your choice will be muffled as it is without cut outs or opening the cut outs to run as straight pipes. The cut outs won’t limit noise to less than it is without them. Of course I guess straight pipe in your mind is the normal mode and then you close the cut outs to run muffled.
04-06-2022, 07:55 PM | #12 |
Arguing? I'm not arguing with you or anyone on this thread. I'm just trying to get the right understanding of everything before I make this decision. Which is why I explained to you what I think cutouts are and why I want to use them.
04-06-2022, 08:01 PM | #13 | |
04-06-2022, 08:27 PM | #14 |
Is not annoying everyone with loud pipes an option?
I don’t know if there are any benefits to removing the cats on the v6 or not so not sure what you are trying to accomplish unless they a failing. If you want more sound, just get an aftermarket “cat back” exhaust which would basically new mufflers. They will be louder but hopefully not to loud. If you must remove the cats, then run them through the stock mufflers. This again will still be louder than stock but probably not too bad. |
