09-20-2017, 01:12 AM | #1 |
1 year after th400 swap
Still lovin it!
Since the swap Ive changed the 3.45 gear out for 4.10s and swapped the 10" 4000 stall out for an 8" 5000. Its a real fun daily for me. Exactly what I wanted ever since I bought this car.
09-20-2017, 03:59 AM | #2 |
Drives: 2012 ZL1 Redline Phase 4 Join Date: May 2017
T400 w/4.1's & 8" 5000 RPM Convertor must be SICK
I would imagine the 1 2 shift is INSANE
2012 ZL1 w/Redline PHASE 4-ZL Performance Package
09-20-2017, 10:19 AM | #3 |
Drives: 2010 Camaro 2SS Join Date: Jun 2015
Sounds close to my setup which has a RMVB and brake 400. Stall was supposed to be 5500 but ended up coming in at around 5300 when I'm on the brake. Went from stock gears to 3.91s and I'm running a 29.10.5W/15 Hoosier. Stalls an 8" billet from Circle D and has done well. I'm spraying the car now and a 75shot that I was using to test its fine but the 200shot it immediately is on the limiter its just blowing right through the stall. Pulled the converter out to send in and I'm going to knock 1000rpm out of it.
09-20-2017, 02:10 PM | #4 |
Yes. The more power you put against a converter the higher it will stall. I was running a mvb but pulled it out. Too much wear on the pump for a daily.
09-20-2017, 03:05 PM | #5 |
Drives: 2019 Camaro 1SS A10 Join Date: Nov 2015
Bo, please forgive my ignorance here. I've been reading through your swap threads and Diet Cokes...bouncing back and forth between a TH400 and 4l80. Each one has its benefits and drawbacks. (like everything else) My question would be this: Does not having lock up negatively effect your ET? My understanding is that at some points, say during a pass on the strip, your converter will go into lockup which increases your wheel hp, because you are now 1:1, correct? So if that is true is the loss of ET negligible if you do not have that ability? I assume it must not be a huge issue since you decided to go TH400.
"Jesus said to them: I am the way, the truth and the life and no one comes to the Father except through me" John 14:6
2020 Mustang GT M6 2019 Camaro 1SS A10 E85/Pray tuned & ported IM/TB.**SOLD** 2018 Mustang GT A10 Kooks Lt's, E85 & Lund tune*SOLD* 2010 Camaro 2SS/RS M6 Silver- CAI, Bo-body, VRSP-2 cam, Kooks 1 7/8 Lt's w/cats, Magnaflow street CB(15089), QTP ovals, Elite can, Vengeance Racing tune. *SOLD* Last edited by gmcvt; 09-20-2017 at 03:20 PM. |
09-20-2017, 05:02 PM | #6 |
Usually locking the converter will give you another tenth depending if the engine is in the meat of the power when your at that point on the track. Thing is the th400 is lighter than the 4l80 and 6l80 so its a wash most of the time. We found that out at CamaroFest7.
09-20-2017, 07:47 PM | #7 | |
2020 Mustang GT M6 2019 Camaro 1SS A10 E85/Pray tuned & ported IM/TB.**SOLD** 2018 Mustang GT A10 Kooks Lt's, E85 & Lund tune*SOLD* 2010 Camaro 2SS/RS M6 Silver- CAI, Bo-body, VRSP-2 cam, Kooks 1 7/8 Lt's w/cats, Magnaflow street CB(15089), QTP ovals, Elite can, Vengeance Racing tune. *SOLD* Last edited by gmcvt; 09-20-2017 at 08:18 PM. |
09-21-2017, 05:15 AM | #8 |
The transmission is lighter and rotating mass is lighter from lockup to nonlockup.
09-21-2017, 10:05 AM | #9 |
Drives: 2010 2SS LS3, 2013 duramax Join Date: Nov 2012
Overdrive and lockup are nice @ 65mph
09-21-2017, 02:42 PM | #10 |
I drive 70 most of the time.
11-08-2017, 07:52 PM | #11 |
Drives: 2010 ss , cam, magnacharger , etc Join Date: Jul 2017
So what are your rpms like driving at 70? I also wanna swap to the th400 . I'm just concerned if I'll be able to cruise at like 65 with my 3.91s and 28" tire...
11-08-2017, 07:53 PM | #12 |
Also what would you say the total cost to swap from a m6 to the th400 is ? Thanks
11-09-2017, 08:05 AM | #13 |
I cruise at 3500rpm at 70
Youcan do the swap for around $3500 nicely
11-09-2017, 06:33 PM | #14 | |
Drives: 2013 Victory red/white stripes SS Join Date: Mar 2013
This certainly backs up Bo's experience as he lost 1/10th from no lock up but gained 1/10th from shedding 100 lbs of weight... thus no net loss or gain. I love it when theory and the real world coincide! faSSteddie |
