05-16-2022, 09:03 PM | #1 |
Drives: Chevy Camaro Join Date: May 2022
Need some help
I have a 2011 chevy Camaro Lt. The Driver and passenger windows won't roll down, or up, radio doesn't time out after turning the car off and opening driver door. When opening the driver door the window doesnt slide down like its suppose to also the dash board doesnt show that the doors are open when they are actually open. The newest thing is that my radio has stopped playing music and doesnt beep when backing up. I have taken it to the dealership and they couldn't figure it out.. I have changed the bcm, switches, fuses, and door actuator on the drivers side. Window motors are good, my battery is brand new and I have checked multiple different grounds. I have tried re- indexing the windows. My next step is changing the wiring harness unless someone else has any information. Tomorrow I am checking the wires behind the radio. Any help would be very appreciated
05-17-2022, 07:59 AM | #2 |
Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3 Join Date: Dec 2021
I'm a little confused. You said neither side window rolls up or down. How did you try re indexing them if they don't move?
05-17-2022, 09:50 AM | #3 |
Press the switches in the downward position for 10 seconds then in the upward position for 10 seconds, obviously it didn't work because the windows dont work right now. Hints the reason why I asked for any more information. They are both rolled up right now.
05-17-2022, 12:38 PM | #4 |
Give me some time...I'm studying it
05-17-2022, 03:23 PM | #5 |
I will give you plenty of time. I have been dealing with it since December
05-17-2022, 03:55 PM | #6 |
There have been reports on here of a heavily corroded connector feeding the door causing problems. Not sure if that is actually in the door or in the jamb. I would hope that the dealer would have checked that. It's possible the radio is unrelated since it didn't start at the same time.
05-17-2022, 05:05 PM | #7 |
I will look into that and I doubt they checked it. The only thing thats new is no sound coming from The radio. All the other issues came at the same time. I pulled the harness off at the door jam and left it off for 15 minutes and it didnt appear to have any corrosion built up but I am going to check it again just in case I missed something.
05-17-2022, 06:18 PM | #8 |
Drives: 2010 2SS/RS Join Date: Feb 2020
05-17-2022, 07:16 PM | #9 |
Have you tried disconnecting the battery for 10 - 15 minutes to reset the systems?
'22 2SS | Wild Cherry Tintcoat | Design Package 3 | NPP | MRC | A10 | NAV | Ceramic Coating | Full Frontal PPF | New Hood and Side Stripes | Michelin PS AS 4
Range AFM Disabler | Mishimoto Catch Can | Diode Dynamics side markers | Cold Air Inductions CAI | LLoyd Velourtex front/trunk mats with Camaro SS logo ZL1addons Deluxe Rock Guards, Stealth Lift Pads, and Tow Hook | Escort MAXcam360c | Footwell Lighting | Banks gauges in ZZPerformance pillar pod | Paddle shifter extensions |
05-18-2022, 05:30 AM | #10 |
SS_Don yes I have done that and nothing.
05-18-2022, 05:33 AM | #11 |
I am giving him time, I have no issue with waiting especially if he can figure out what the issue is.
05-21-2022, 01:39 PM | #12 |
the radio fixed itself so I am assuming it has a short or the radio is going bad. Still having the other issues
05-22-2022, 05:56 AM | #13 |
2011 Camaro RS conv
Drives: 2011 camaro rs Join Date: Jun 2021
I had something similar on one of my Corvettes. Some of the wires between the drivers door and body were being pinched/bent/shorted and causing issues that would come and go. Power windows, radio, interior lights, dash, ect were all affected.
05-22-2022, 04:14 PM | #14 |
I was thinking that at first but door locks and the lights on the doors still work. But I will most definitely check on that. I think the issue is in the drivers door for sure
