Old 04-22-2022, 06:42 PM   #1
Nz2ssrs
Drives: 2012 2ssrs giovanna edition (japan)
Recalibrating speedometer
Hi guys,
My Speedo on my 2011 ss is reading well off and I need to recalibrate it.
Before I brought it it was on 22” wheels but I’m not sure the tyre size. It now reads 113km when sitting at 100 so am thinking it’s been recalibrated for the 22” wheels but it’s now on factory size.
What’s a scan tool that will allow this change? Not wanting anything too flash as it’s already getting a dyno tune in a week so won’t be used for tuning.
Thanks
Nz2ssrs is offline   Reply With Quote
Old 04-22-2022, 07:19 PM   #2
KillboyPowerhead
Drives: 2015 Z/22
Your tuner will be able to address the issue during the tune
Overkill/Self Tuned; Mace Camshafts; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
KillboyPowerhead is offline   Reply With Quote
Old 04-22-2022, 08:30 PM   #3
Car Nation Videos
YouTube-Car Nation Videos
Car Nation Videos's Avatar
Drives: 2010 Chevrolet Camaro
Originally Posted by Nz2ssrs View Post
Hi guys,
Thanks
I would try disconnecting the battery completely for about 30 mins.
Car Nation Videos is offline   Reply With Quote
Old 04-23-2022, 05:42 PM   #4
Nz2ssrs
Yea funny enough I had it disconnected for 24 hours but have not checked since.
Old 04-24-2022, 09:26 AM   #5
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Disconnecting the battery won't change the tune...
Mr_Draco is online now   Reply With Quote
Old 04-24-2022, 11:28 AM   #6
chevy pilot
chevy pilot's Avatar
Drives: 2010 2SS/RS A6
With handheld tuners (Hypertech,Diablosport,Edge etc.) or HPTuners,EFILive.
Old 04-24-2022, 08:40 PM   #7
RS/SS '10
Drives: 2010 2SS/RS
Call your local GM dealer, set an appointment to have them flash the speedo.
RS/SS '10 is offline   Reply With Quote
