Old 05-04-2019, 04:51 PM   #1
wwiiavfan
Drives: 2017 1SS Hyper Blue
ZL E reps fitment on SS?
I accidentally posted this in the for sale wheel & tire section, so reposting here:
I have a line on some used ZL1 1LE replica wheels. description is 19x10 & 19 x 11 with 23/38 offset. Think these would fit my 17 SS? I have the standard Brembos. What tires would be the recommended size?
wwiiavfan is offline   Reply With Quote
Old 05-04-2019, 05:23 PM   #2
Alpha1BC
Alpha1BC's Avatar
Drives: 2017 1SS 1LE
I'd expect them to fit. Comparing to the SS 1LE and ZL1 wheels which also fit your car, the dimensions given are +3 mm front offset, -5 mm rear offset, same width all around, and -1" diameter all around.
I'd say tires sizes to start looking at would be 285/40R19 and 305/35R19 to match the widths of the SS 1LE and ZL1, but adjusting diameter and AR to get you closer to the OE radius of the SS for speedo consistency. You could easily take the aspect ratio down to 30 on both front and rear and/or go ±10mm width since the sizes I mentioned are kinda odd and might be tough to get a full vehicle set of matching tires, but keep in mind the further the tires are from the OE radius the more the speedo will be off if that's important to you.
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
Old 05-04-2019, 07:53 PM   #3
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
MRR made these wheels specifically for Camaro owners wanting the ZL 1LE look. They will fit Perfectly.
285/35 and 305/30
BradfordCamaro is offline   Reply With Quote
Old 05-04-2019, 08:49 PM   #4
wwiiavfan
Thanks for the replies. I’m a little concerned about the offsets. I don’t want them outside the fender line. Think I will be ok there?
Been looking for photos of this exact setup, but haven’t found any yet that confirm those offsets on a SS.
Old 05-04-2019, 08:57 PM   #5
BradfordCamaro
SABIO
https://www.camaro6.com/forums/showp...&postcount=129
Old 05-10-2019, 12:50 PM   #6
YoungFamous
Amos6.2Jr
Drives: 21 A10 2SS 1LE
Will the ZL11LE 305/325 30 19s W/T fit on a 2SS with MRC?
YoungFamous is offline   Reply With Quote
Old 05-10-2019, 01:08 PM   #7
Osbornsm
Drives: 2018 SS 1LE
The 11" wide fronts from the ZL1 are too large for the SS fenders.
The ZL1 fenders are wider to accomodate the larger front tire.
So... no.
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si
Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8
Results: 470 hp / 447 tq
Osbornsm is offline   Reply With Quote
Old 05-10-2019, 02:13 PM   #8
wwiiavfan
I took a pass on these, but if someone else is interested, they are on eBay for $450 for the set ( I confirmed the set)
Weird though, they told me they wouldn’t clear the Brembos?
