BeckyD @ James Martin Chevy
Old 08-05-2017, 08:04 PM   #1
wwiiavfan
Drives: 2017 1SS Hyper Blue
Headliner flutter
I tried searching for this without success so sorry if it has been covered before.
Does anyone have a fix for the headliner fluttering above 40 mph with one or both windows down?
It acts like a giant speaker and it is hard on your ears. Would like to cruise with the windows down but it kinda sucks right now.
wwiiavfan is offline   Reply With Quote
Old 08-05-2017, 08:46 PM   #2
Camaro_Club
Camaro_Club's Avatar
Drives: 2017 1SS NPP A8
I happened to notice this the other day. I thought about putting some kind of glue under the edge of it but I'm afraid I'll make a mess. It does seem like this car is prone to making a flutter sound when traveling at speed. Kinda the same noise other cars make if you only have one window down at a time. I usually only roll both windows halfway down to prevent that noise.
Camaro_Club is offline   Reply With Quote
Old 08-07-2017, 05:35 PM   #3
nfboy
Drives: 2017 Camaro 1LT HBM
You sure it's the headliner and not just normal baffling?
nfboy is offline   Reply With Quote
Old 08-07-2017, 05:47 PM   #4
396ssrat
Drives: 66 Chevelle SS
Funny this would come up. The window regulator in my '11 Silverado went south and the rear passenger window got stuck in the down position. The "Flutter" noise was unbearable. "Flutter" is a good description. Btw, my '66 Chevelle doesn't suffer from this anomoly with 1 window down.
66 Chevelle SS 396
91 octane Driver n/a
6.44@105.78 1/8th mile
396ssrat is offline   Reply With Quote
Old 08-07-2017, 05:51 PM   #5
Johnwon
Drives: 2016 Mosaic Black 2SS, NPP, A8.
That's the reason I got my car with a sun roof. When it's open, you don't get the noise.
Sent from the mobile client - Forum Talker
Johnwon is offline   Reply With Quote
Old 08-07-2017, 06:11 PM   #6
nbryant
nbryant's Avatar
Drives: 2016 2SS Red Hot
Buffeting is an issue and usually corrected by only cracking the passenger window open or opening the sunroof (if you have one) to relieve the pressure being created. Funny, I was trying to find the other threads here regarding this and stumbled across this instead:
https://gm.oemdtc.com/6666/pic6189-w...evrolet-camaro
2SS, A8, NPP, Nav, Sun Roof, Bose Audio, MM Catch Can, RPI chin splitter
nbryant is offline   Reply With Quote
Old 08-07-2017, 06:59 PM   #7
lt4camaro
lt4camaro's Avatar
Drives: 2021 LT1 10 speed auto
I experience the same thing anytime I go over 60mph on the highway with 1 window down. Reach back with your hand and press on the headliner, you can feel it fluttering.
lt4camaro is offline   Reply With Quote
Old 08-07-2017, 08:37 PM   #8
RJT Impala
Stovebolt BluFlame 6
RJT Impala's Avatar
Drives: '12 2LT/RS, IBM; '20 Traverse Prem
Hmmmm...I've learned something new. I had always thought that it was just buffeting due to air pressure differential since I simultaneously experience pressure changes in my ears corresponding to the frequency of the fluttering; lowering a second window makes it go away. I also experience the same thing in my '14 Malibu.
RJT Impala is offline   Reply With Quote
Old 08-07-2017, 10:02 PM   #9
wwiiavfan
Seems that bulletin doesn't give any remedy. I was hoping there were maybe some Velcro or similar fasteners that could be installed at the center of the headliner to keep it from acting like the speaker at the beginning of Back to the Future.
Old 08-08-2017, 06:45 AM   #10
Camaro_7888
Drives: .
It's not just a Camaro issue. I've had this problem when I owned a Jeep Patriot, & my 2014 Silverado did it as well, no TSB's were ever created for it either. Would sound like a helicopter taking off. Its just the air rushing in the car through the headliner, not much can be done.
Camaro_7888 is offline   Reply With Quote
Old 08-08-2017, 07:11 AM   #11
rootus
Drives: 2018 HBM SS 1LE
I think you have cause and effect reversed.
rootus is offline   Reply With Quote
Old 08-08-2017, 07:49 AM   #12
Camaro_7888
Drives: .
All I'm saying that it isn't just a Camaro issue.
Old 08-08-2017, 07:53 AM   #13
nearwater
nearwater's Avatar
Drives: '17 2SS 50th
+1
'17 2SS 50th Anniversary | M6 | MRC | NPP | Nav | Sunroof | Black bowtie | GM dark tail
nearwater is offline   Reply With Quote
Old 08-08-2017, 07:55 AM   #14
nearwater
nearwater's Avatar
I believe rootus was replying to OP.
The buffeting/pressure change is causing the headliner to 'flutter'.
