10-22-2018, 12:34 PM | #1 |
Drives: 2017 Camaro 1SS M6 (SOLD) Join Date: Oct 2016
My best Whipple pass yet
The weather is good this time of year, lots of faster times out there.
New personal best, still on street tires, same setup as last time out when i went 11.40 @ 128!!! Took tires down to 22psi, and instead of leaving off idle, was giving it 2-3k of rpm when leaving. Just waiting for my wheels to come in, already have my DR's and skinnies to put on, hopefully have some time yet to get them on and get to the track. made 12 passes this day, a bunch of 11.0's, 11,10's, slowed down as the day went on and the track seemed to go away. No lift shifting all day, grabbing 2nd it broke loose spinning a little, sometimes a little wheel hop. https://youtu.be/VETEBnqSeZ0 2017 1SS M6 Tires used on the pass: Continental Extreme Contact Sport 305/35/20 Performance Mods (if any): Whipple SC, LT4 Fueling, CAI, stock headers, full cat delete, full Borla ATAK, tuned by CSP. Race Weight: 3975# with 1/2 tank of 93 fuel Category submitted for: Category #5 M6 R/T.......... .415 60'............. 1.738 330'........... 4.686 660'........... 7.088 660’ mph... 103.28 1000'.......... 9.138 1320'.......... 10.871 1320’ mph… 128.93 Name of the track: Maple Grove Raceway Date of pass: 10/20/18 Weather conditions: 836 DA.
2017 1SS M6 Hyper Blue Metallic NPP, MMR 228 Z/28 replica wheels, Front: 20 x 9, Rear 20 x 11
Stock: 416hp/427tq, 12.21 @ 116.80 Modified 02/2019: Whipple SC w/ 3.500 pulley, LT4 fueling, NW 103 TB, Roto-Fab Big Gulp, Kooks 2" jet coated, full Borla ATAK exhaust, DSS axles, Gforce driveshaft. Tuned by EFX Tuning 688hp/632tq Best 1/4 to date: 10.705 @ 131.92 |
10-23-2018, 06:30 AM | #2 |
Drives: 2017 1SS A8 Nightfall Gray Join Date: Feb 2017
This is Great , clutch and street tires
Awesome!!!
10-23-2018, 11:19 AM | #3 |
Drives: 2018 ZL1 Join Date: Jul 2017
How much boost are you running?
Mark E.
2018 ZL1 NGM A10 87 Grand National. Modified Hot Rod for sale *SOLD* 87 Grand National. Stock 65 Olds Vista Cruiser wagon Grand National motor/tran 66 Bronco Rockbuggy 2006 Dodge 2500 4x4 Cummins 6 speed |
10-23-2018, 11:39 AM | #4 |
Great pass, some aren't doing that on drag radial with A8. Good driving also, takes some skills to get where you are with an M6 and 1.73 on street tires makes it more impressive.
10-23-2018, 12:51 PM | #5 |
My P3 gauge with the analog boost read 11.0-11.4 the times I checked it. I dont log my runs.
10-23-2018, 12:52 PM | #6 |
Thank you! Means a lot coming from you!!!
10-23-2018, 01:52 PM | #7 |
I'm an equal opportunity congrats guy no matter what system you run. We all work hard to make sure these cars perform their best. I always appreciate hard work, your doing that. You need to put a hoosier slick on that Camaro and you'll improve those 60' times. So save some bucks and get that done. You could for sure get below or around 10.50 with those. The slicks usually help your mph also since they grow on the big end where a drag radial or street tire stays flat all the way down the track. I run the 28x10-17 Hoosiers on a 17x9.5 race star wheel. Skinnies up front. A few years back I had a NA C5 vet with M6 and launching is an art and I worked very hard like you to get the most out of that car, broke a lot of shit with a drag radial so that's one valuable lesson I learned so I pass that on to the M6 guys so they don't tear shit up
10-23-2018, 02:08 PM | #8 |
Agreed...I bet it would go 10.4 on a slick. You have to factor the gains from a lighter wheel too. Most running good times are on a drag pack not 20" wheels.
2016 NFG 1SS A8
10-23-2018, 02:12 PM | #9 |
I save 100 lbs over the stock wheels/tires.
10-23-2018, 02:52 PM | #10 |
I have the tires, waiting on wheels to be instock and ship, should be this week. The rear tires are bias plys.
Front Wheels: Race Star 92's 17x4.50 5x120BC 1.75"BS GLOSS BLACK Tires: M/T ET FRONT 27.5/4.0-17 Rear Wheels: Race Star 92's 17x10.5 5x120BC 7" BS GLOSS BLACK Tires: M/T ET STREET R BIAS 28x11.5-17 I would be pumped with anything better than 10.499. If published weights are true on both my current and incoming setup, I should save 132 lbs total, all rotating mass. I am alittle afraid of breaking axles or driveshaft.....that is next on the list.
11-02-2018, 02:23 PM | #11 |
Drives: Sold-G8 GT H/C/I Join Date: Sep 2018
Fantastic times M6 be proud!
11-11-2018, 09:10 PM | #12 |
Drives: 1SS Summit White 6 speed Join Date: Jul 2017
Your track must be prepped well.
I haven't gotten a single clean run since I've been boosted
16 1SS M6 White
Magnuson 2.3 Heartbeat Roto Fab Solo Performance Cat deletes and Axleback Hurst short shifter #'s coming soon Riaction coilovers 1LE sway bars BMR mm BMR chassis brace Flow one 19" wheels wrapped in Mickey Thompsons 02 Z28 M6 35th anniversary 80k miles T-tops Leather Bolt ons Joy to drive this classic every day! Daily Driver |
11-11-2018, 09:20 PM | #13 |
Drives: 2018 camaro ss Join Date: Aug 2013
Very nice congratulations
2019 charger scatpack FBO 11.16@122
2020 CAMARO LT1 6spd 11.02@ 135 dragy approved |
11-12-2018, 12:06 PM | #14 |
Got my drag pack on and just trying to find a day/night that works to get to the track.
Using a bathroom scale I weighed both my street and drag setups: Street Front: MRR M228 20 x 9 with Continental Extreme Contact Sport 275/35/20 = 56 lbs each Rear: MRR M228 20 x 11 with Continental Extreme Contact Sport 305/35/20 = 60.5 lbs each Track Front: Race Star 92's 17x4.50 with M/T ET FRONT 27.5/4.0-17 = 33 lbs each Rear: Race Star 92's 17x10.5 with M/T ET STREET R BIAS 28x11.5-17 = 52.5 lbs each. Savings Front: 23 lbs each Rear: 8 lbs each Total: 62 lbs I feel like the track setup weighed more than the published weights, I don't know if it is the tires or the wheels. Also I did have to move the harness in the driver side rear wheel well.
