07-22-2017, 05:04 AM | #1 |
Drives: Gen 6 ZL1 White Join Date: Jul 2017
New ZL1 Issues
I've had my ZL1 coming up to two months and the list of issues is getting longer! Nothing is critical but all stuff that I need sorting out:
1. Rear bumper paint cracking at corner (common issue) 2. Air conditioned seats don't always work properly 3. Trunk release is occasionally works 4. Front screen fogs up in slow or standstill traffic (common issue #17-NA-201) 5. FM radio reception is terrible 6. Knocking from the front over speed bumps - loose sway bar PIC6276 7. Aggressive shift from 4th to 5th when driving hard 16NA019 Can anyone comment on the above? Would be good to have some ammo before taking it into Chevrolet. Thanks, Bunksy. Last edited by Bunksy; 07-23-2017 at 04:21 AM. |
07-22-2017, 05:06 AM | #2 |
Drives: Big Brown Join Date: Dec 2016
#6 sounds like the sway bar needs to be tightened...there is a TSB on the issue...
The rest??? |
07-22-2017, 05:32 AM | #3 |
Thank you Al Oppenheiser!
#2 - the AC has to be on in order for the seat cooling to work.
07-22-2017, 05:35 AM | #4 |
07-22-2017, 05:51 AM | #5 |
CamaroFans.com
These are not A/C seats. They are ventilated.
Wondering about that TSB with front window fogging up. Is there a fix? |
07-22-2017, 06:28 AM | #6 | |
Hmmm only ventilated seats? In theory whatever temperature air comes out of the dash vents should also come out of the seats! |
07-22-2017, 06:44 AM | #7 |
I believe the ventilated seats simply are driven by a fan, and not connected to the interiors cooling system in any way.
07-22-2017, 06:50 AM | #8 |
Drives: '21 ZL1 A10 Convertible Join Date: Sep 2015
My C7 Corvette has ventilated seats. They work much better when the floor vents are run along with the dash vents. Cold air directed right on the floor can better feed the seat fan. Only negative is the dash vent pressure isn't as strong when running the floor vent too.
07-22-2017, 07:42 AM | #9 |
Drives: 2019 Shock ZL1 Join Date: Jan 2007
That is not the case. All they do is vent the heat out of the seats. There is no control of the temperature of them.
From Super Chevy mag, April 2002: "Most of the weekend Settlemeire was meeting and greeting and quickly became known as simply "The Camaro Dude" (note, even his initials are SS)."
07-22-2017, 08:19 AM | #10 |
ventilated seats are "fan only"
07-22-2017, 09:36 AM | #11 |
Drives: 2017 ZL1 A10 (Summit White) Join Date: Apr 2017
#3 yes, I'll be taking this into the dealer to fix that trunk. Sometimes the trunk doesn't open even though the computer thinks that it is. Which requires me to go through the car, pull down the back seat and pull/lift up my trunk from the inside of the car.
07-22-2017, 09:44 AM | #12 | |
Drives: A10 LT4 Join Date: Aug 2016
Proper AC is mighty important right now...I do wish the seats had full blown AC. I'll likely never use the heated seats / wheel. |
07-22-2017, 09:51 AM | #13 |
Drives: 2018 ZL1 1LE, 2017 Ford Raptor Join Date: Apr 2017
Not sure why you're having an issue on the A/C seats. Mine get cold fast. And I don't believe it's accurate to say these seats only take out the hot air. They are paired in conjunction with the A/C cause there is no way mine blows that cold when the temperature outside is 100 degrees. They should be working in conjunction with your A/C and ventilate the cold air into them.
07-22-2017, 12:33 PM | #14 | |
Drives: 2016 Z06, 2017 ZL1 Join Date: Feb 2012
What exactly do you mean by front screen? |
