AWE Tuning
Old 01-20-2019, 09:59 PM   #1
RSFR
RSFR's Avatar
Drives: ZL1
Replacement Brake Rotors
Front rotors are starting to crack and warp and I'm looking to upgrade from stock, but I can't find much of anything. Looking to stay with steel rotors, not CCB.
All I've found so far is this offering from RacingBrake: https://www.racingbrake.com/RB-2pc-R...-ZR-p/2543.htm
Is that all that's out there? Anyone else find anything?
RSFR is offline   Reply With Quote
Old 01-21-2019, 07:16 AM   #2
SteveV
SteveV's Avatar
Drives: 2018 ZL1 Camaro 6M Red Hot
If your hubs are still straight and the warping/cracking is limited to just the rotor rings, this is another option: https://www.knsbrakes.com/c/car-seri...M+GM+Rotor+Hat
There is a good write up in the general forum where a guy with a 1SS 1LE and the 6 piston brakes upgrades to these rotor rings.
Apparently the ZL1 and Z06 with steel brakes use the same rotor ring, but a different hub.
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
SteveV is offline   Reply With Quote
Old 01-21-2019, 07:58 AM   #3
2010REDSS
2010REDSS's Avatar
Drives: 2018 ZL1 1LE
Thanks for starting this thread OP!
Was about to do the same.....need to upgrade the rotors for next track season.
2018 ZL1 1LE "RAZECAR"
2016 2SS Convertible "NOTOPSS" (Sold)
2015 Z/28 #306 "ITZFAST"
2010 2SS Coupe "FASSTER" (Sold)
2002 SS/RS "02FASST" (Sold)
2007 Factory Five Racing GTM "REDBLUR" (Sold)
"There are two kinds of cars. Red....and everything else!"
2010REDSS is offline   Reply With Quote
Old 01-21-2019, 08:02 AM   #4
MX621
MX621's Avatar
Drives: 2014 z28
How much track time are u getting from the front rotors? I’m gonna switch over to the zl1 front rotors on my z/28 over the winter.
MX621 is offline   Reply With Quote
Old 01-21-2019, 08:02 AM   #5
harner
harner's Avatar
Drives: 2018 ZL1 A10
Check out R1 Concepts. I have used them before specifically on street cars and they held up just as expected.
SOLD! 9/1/2020 2018 ZL1 A10 Hyper Blue - Rotofab CAI, Gibson catback
@SurefireDetail
OEM ZLE tails/third brake light, Gen5DIY reverse LEDs, front Amber LEDs, SMG laser LED side markers, SMG smoked reflectors
1994 Trans Am LM7/CPT 4L60E/9"
1987 IROC
2006 Silverado
harner is offline   Reply With Quote
Old 01-21-2019, 08:09 AM   #6
MX621
MX621's Avatar
Drives: 2014 z28
I do not believe this is true. Zl1 use a 390mm rotor, the c7z iron rotor is a 371mm which is the same as the ss/1le
Old 01-21-2019, 09:56 AM   #7
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
The J6M SS 1LE front rotor is same OD and thickness as the J56 steel front on GS & Z06 but the J56 is slotted (with different hat vs. J6M).
RUQWIKR is offline   Reply With Quote
Old 01-21-2019, 10:43 AM   #8
RSFR
RSFR's Avatar
Drives: ZL1
They don't have any offerings for front rotors on the ZL1.
Seems like brake companies aren't very interested in making parts for the ZL1.
Old 01-21-2019, 12:14 PM   #9
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
I recommend using KNS Brakes. Just go on their website, input the year/make/model and you'll see a variety of options. I used and like the DBA options on other vehicles. Pair with Carbotech pads and you'll stop like hitting a brick wall. If you want to call them, they'll be able to set you up with exactly what you need.
It does appear at this time there is no front rotor option for the ZL1. Which kind of sucks for track rats. I'm sure somebody with more know-how than me will figure this out.
Can'tHave2MuchHP is offline   Reply With Quote
Old 01-21-2019, 01:59 PM   #10
nicktechla
nicktechla's Avatar
Drives: 2012 Porsche 911 Turbo S
Originally Posted by Can'tHave2MuchHP View Post
I recommend using KNS Brakes. Just go on their website, input the year/make/model and you'll see a variety of options. I used and like the DBA options. Pair with Carbotech pads and you'll stop like hitting a brick wall. If you want to call them, they'll be able to set you up with exactly what you need.
do they come with new hardware? or do you just re-use the same mounting hardware?
IG: 2fast2nick
-- Current --
2012 Porsche Turbo S - PDK - Basalt Black Metallic
-- Past --
2017 Camaro ZL1 Coupe - Red Hot - A10, PDR - HRE P101
2015 Mustang GT PP - Whipple Supercharger
nicktechla is offline   Reply With Quote
Old 01-21-2019, 02:05 PM   #11
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
At this time I do not believe there are any aftermarket options for the ZL1 front rotors. You are stuck with buying new OEM rings (which isnt a bad thing).
seanblurr is offline   Reply With Quote
Old 01-21-2019, 02:06 PM   #12
nicktechla
nicktechla's Avatar
RacingBrake sells them, but I've heard mixed reviews on them.
IG: 2fast2nick
-- Current --
-- Past --
Old 01-21-2019, 02:45 PM   #13
SteveV
SteveV's Avatar
Read this: https://www.camaro6.com/forums/showt...ight=KNS+rotor
Old 01-21-2019, 04:40 PM   #14
MX621
MX621's Avatar
Drives: 2014 z28
I’m a little confused. That’s for a ss/1le. Zl1’s have larger rotors and diff calipers then the ss/1le. So that thread does not apply to zl1 owners. I wish it did, I’d already have them. As seanblurr already said, zl1 owners are stuck with oem front rotors for now.
