Go Back   CAMARO6 > Technical Camaro Topics > Camaro DIY & HOW-TO instructions & discussions
Old 03-02-2017, 07:52 PM   #29
RobertAvitia
BYND GARAGE
RobertAvitia's Avatar
Drives: 17' 1LT Turbo
Originally Posted by metwaru View Post
Update. I added the second fuse (10A) that was removed from spot #50 to the gen5dyi fuse harness, disconnected battery for 15mins and the check engine light is gone.
That's exactly what I did
RobertAvitia is offline   Reply With Quote
Old 03-05-2017, 09:26 PM   #30
Commando16SS
Drives: n/a
Originally Posted by RobertAvitia View Post
Watch my video(link below) but the entire bumper does need to be removed and 4 bolts hold the housing of the headlights onto the car. I believe the computer of the car adjust the headlight lens inside the headlight itself so no adjustments are needed
There's no link in your post.
The computer does not adjust the height - on top of the headlight housings, there is a single hole with a white phillips head screw at the bottom. You will need a fairly long screw driver with a smaller head in order to reach it but the screw turns plastic gears that points the HID either up or down. Taking the bumper off for vertical adjustment is not needed.
Commando16SS is offline   Reply With Quote
Old 08-22-2017, 12:12 PM   #31
Phoenix_Gilmore
Phoenix_Gilmore's Avatar
Drives: 2020 2SS
Anyone else having issues with there harness? Gen 5 sent me a new one because my old one stopped working and now the new one won't turn on the bottom drls
Phoenix_Gilmore is offline   Reply With Quote
Old 01-09-2020, 12:26 PM   #32
Scottybig42
Drives: 2011 as camaro
Non rs to rs healights
2ssgen5diy do you still have any harnesses to swap rs headlights into a ss?
Scottybig42 is offline   Reply With Quote
Old 01-09-2020, 03:37 PM   #33
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
RS and SS headlights are the same
Bumbleboy92 is offline   Reply With Quote
