AWE Tuning
Old 06-21-2019, 04:33 PM   #1
Frans96ss
Frans96ss's Avatar
Drives: 96SS
Arrow Building a 1,000+ whp Camaro SS
This beautiful 2018 Camaro SS 1LE (2,000 miles on it) came into our shop wanting to make 1,000 whp.
The Mod list.
- 2” ARH Long Tube Headers w/ 3” Off-Road X-Pipe
- F1A-94 Procharger Supercharger System
- RPM Custom Camshaft Package (Includes - RPM Custom Spec’d Comp Cam w/ Increased Fuel Flow Lobe, Brian Tooley Racing Dual Valve Spring Kit, Brian Tooley Racing 3/8" Hardened Pushrods, ARP Head Stud Kit, Katech C5R Timing Chain, GM LS7 Lifters w/ GM Lifter Trays, GM MLS Cylinder Head Gaskets, Katech Valley Cover, Comp Phaser Limiter, GM VVT Cam Bolt, BTR 160* Thermostat, GM Crank Bolt, GM RTV Sealant, Mobil 1 Oil & Filter Change and NGK Spark Plugs
- Katech Performance Valve Covers w/ Race Proven Motorsports Inserts
- RPM Meth System, Stainless Steel Lines, Standard Trunk Mounted Tank, Dual Nozzles, Snow Solenoid and AEM Controller
- Race Proven Motorsports Custom External Low-Side Fuel System w/ Flex Fuel. LT4 High Side pump and LT4 Injectors.
- MSD Atomic Intake Manifold
- Monster LT1-S Clutch
So like any car that comes through are shop we got it strapped down on the dyno to get some baseline numbers.
Then came time for the build.
Our guys made quick work removing the engine and trans.
(see the video above for full timelapse)
[img]https://live.staticflickr.com/65535/47959169006_8e53ab6c59_b.jpg/img]
We then removed the weakest link... the rods and pistons
Measuring and cutting rings, labeling and staying organized.
New bearings as well.
Drop in pistons going in
New Monster LT1-S Triple disc on as well as the stock heads (upgraded valve springs and pushrods)
More in our video's about it going together.
Our Meth setup
And the final numbers and video
If you have questions regarding price and or scheduling please email us sales@raceprovenmotorsports.net
Frans96ss is offline   Reply With Quote
Old 06-25-2019, 08:42 PM   #2
ToneCapone
ToneCapone's Avatar
Drives: 2023 ZL1
This is all so cool to me. I envy whoever it is getting this done.
2018 2SS Redline (SOLD)
Borla ATAK Cat back system
GM Performance Cold Air Inductions CAI
2023 ZL1 M6 Black
ToneCapone is offline   Reply With Quote
Old 06-25-2019, 10:19 PM   #3
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Air filter looks comically small ! Now results w hood closed ?
ing for grip.
Are you in the NY/NJ/PA/CT region? Join us for autox fun at MetLife Stadium. HUGE lots, tons of runs.
http://www.motorsportsne.com/
Vtor_ZL1 is offline   Reply With Quote
Old 06-27-2019, 10:52 AM   #4
Gator2SS
Drives: 2016 2ss
This car is Beautiful < I watched the build and love the work Matt did. From one Matt to another I want him to do my work some day.. Hope to see you guys at ls fest or camaro fest.. Keep up the great work..Thanks for listing all the parts and work done..
Gator2SS is offline   Reply With Quote
Old 07-04-2019, 04:21 PM   #5
flaudia402
Drives: 2018 SS 1LE
How reliable is this on a daily basis?
flaudia402 is offline   Reply With Quote
Old 07-08-2019, 12:01 PM   #6
Frans96ss
Frans96ss's Avatar
Drives: 96SS
Everything we build we always built to be beat on with no worries. So this setup would be perfectly fine in any conditions honestly.
