03-31-2024, 05:36 PM | #1 |
Drives: 2016 Chevrolet Camaro 2SS Vert Join Date: Apr 2023
2016 SS Cooling problems
Hey yall, so Ive been having the famous thermostat/sensor problems with my cooling system in my 2016 SS.
I got the car a year ago, as soon as I got it, it also had the same typical problems, thermostat sticking open, causing the temp to be pegged at bottom, turning off rev match, fans running on high and No AC. I ended up getting the Thermostat and Temp sensor replaced at Firestone back in May/June of last year and all was good until January this year. Coolant temp gauge acts a lil different this time, on the highways, it shows lower temps (around 190°) rather than the regular 11 o’clock position it’s supposed to be staying at. After driving for a bit on the highway, it would eventually just show me “Active rev match off” message and the gauge would just fall down to 160° and stay there, with fans running high and no AC. It would stay unless I disconnect and reconnect my battery. The only other temporary work around that I’ve noticed is letting my car warm up, then shutting the car off and turning it back on again. This would prevent the whole sensor dropping to zero ordeal, but the temps still drop on the highway instead of staying stable. Obviously I don’t want to have to start my car twice every time. It’ll wear out my starter and battery way quicker, so I’m going to replace my Thermostat housing myself this time. Any recommendations on which ones are good? I’ve only seen the one available at Autozone from Duralast, but not sure if the quality there Thanks |
04-01-2024, 09:36 AM | #2 |
I think you just need the thermostat, not the whole housing. I think the firestone shop may have replaced your thermostat with a lower temp unit, or a less reliable one. We need to dig up the old thread with discussion of exactly which temp and brand of thermostat to buy. There were reports of problems with "off" brands.
https://www.camaro6.com/forums/showp...54&postcount=6 That thread shows the right temp, which is 90 deg C or 194 deg F. Hopefully someone chimes in with the correct brand. |
04-01-2024, 10:05 AM | #3 |
Drives: 2016 2SS Convertible Join Date: May 2012
Maybe check the temperature sensor cable to make sure it isn’t loose or damaged?
04-01-2024, 10:28 AM | #4 |
Camaro #4
Drives: 2017-Hyper Blue Metallic-2LTmanual Join Date: Dec 2015
My '17 is at the dealership as we speak for the same issue. From what I gather from my regular mechanic (he's not doing the work b/c he doesn't accept the 3rd party warranty I bought with the car), is that Dexcool is a suspect in these GM thermostat issues, with it's wanting to gum up the thermostat. I asked if there was a way to prevent it from happening, and he said that only by power-flushing the cooling system, then replacing the Dexcool with a "normal" coolant is the only thing he would suggest as a 'fix.'
Don M
Supercharged LGX + 6 speed manual = FUN!! |
04-05-2024, 03:37 PM | #5 | |
04-05-2024, 03:38 PM | #6 | |
04-05-2024, 04:05 PM | #7 |
Drives: 2016 Black 1SS, M6, NPP, Mag Ride Join Date: Nov 2023
I dealt with this same problem for around a year. I just would pull over and disconnect the battery, hook it right back up, and all was well. It didn't happen constantly, but enough where I finally fixed it.
I had the thermostat changed because it was sticking open, and I've not had any problems since. It sounds like maybe lightening struck twice and it needs another thermostat. Though it could also be the sensor. Good luck with it. It can be a PITA, especially if you live in a hot state like mine in Texas and it happens in rush hour traffic on the way to work in over 100 degree weather. |
04-08-2024, 04:57 PM | #8 | |
04-08-2024, 05:17 PM | #9 |
Drives: Camaro SS 1LE Join Date: Feb 2024
Had the same problem with my Tahoe. Replacing the thermostat didn't do anything for us. There was a leak in the AC condenser and after we replaced that the problem went away.
2018 Camaro SS 1LE (Garage Queen)
2000 Camaro SS FBO (Sold) 1996 Camaro Z28 (RIP) 2020 Mercedes A35 AMG (Daily) |
