Old 12-13-2014, 12:36 AM   #15
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
..boot.boot.reboot
2010SLVRBULIT is offline   Reply With Quote
Old 12-13-2014, 12:40 AM   #16
Blueraycamaro
Drives: 2013 2LT RS camaro
Originally Posted by PR325xi View Post
Has this happened more than o ve to your car? It's the first time for me.
Only once and I still have the problem, it occurred on Nov 7 2014. I just went to car started it up and the screen was blank. I took it the dealer and it stood 5 days at the dealer, they said they order a cable/harness. I go back the dealer this tuesday to get it fix.
Blueraycamaro is offline   Reply With Quote
Old 12-13-2014, 12:43 AM   #17
PR325xi
Drives: 2013 2LT RS
Oh now I'm worried, did you tried the battery reset before going to the dealer?
PR325xi is offline   Reply With Quote
Old 12-13-2014, 11:00 PM   #18
Blueraycamaro
No because I didn't want to reset anything
Old 12-13-2014, 11:03 PM   #19
PR325xi
Drives: 2013 2LT RS
Oh ok, i Just had to adjust the clock and roll down and up the windows after the battery reset. If I took it to the dealer that probably what they'd do and send me on my way anyways.
Old 12-14-2014, 03:39 PM   #20
Blueraycamaro
Well my dealer had my car for 3 days and still didn't fix it, said it some harness/cable that is burnt out. I take it back to them this tuesday.
Old 01-01-2017, 01:45 PM   #21
allblackeverything
Drives: 2013 Camaro SS RS Black
Ok, so I just turned my car on and my screen is all black, but the radio works.
https://vimeo.com/114395744
Don't really like the idea of commenting on a thread that is 2 years old, but want to put my experience out here for others in case they run into this same issue.
I had the exact issue as the original poster, the radio worked, steering wheel buttons worked to control the radio, and even the touch screen worked (pushing where the buttons on the screen would be worked to change channels, etc), just couldnt see anything on the screen (totally black). This issue came up probably 3 weeks ago and never self corrected.
What fixed it for me was just disconnecting the negative battery terminal in the trunk (10mm socket, remove single bolt, very simple) and leaving it disconnected for about 15 minutes and then re-connecting it. When I started it up it worked like a charm and all of my radio settings were still there even (didnt have to reprogram the windows either thankfully). Only things that I notice so far that were affected were the compass had to recalibrate itself and the clock had to be reset.
Hope this helps someone in the future, cheers
allblackeverything is offline   Reply With Quote
Old 02-24-2018, 03:11 PM   #22
Jackass
Doing what I like to do
Jackass's Avatar
Drives: 1963 Landrover
Good info , I just had the exactly problem above discribed and I'm happy to have find the this post , it worked like you said , piece a cake
Thanks
Jackass is offline   Reply With Quote
Old 04-15-2018, 10:36 AM   #23
xmattyx
mattyv
xmattyx's Avatar
Drives: 2017 Camaro 2SS
Thank you guys for thr direction! Easy fix!
2017 Chevrolet Camaro 2SS
2017 Jeep Grand Cherokee
2015 Jeep Compass (sold)
2014 Hyundai Sonata GLS (sold)
2013 Chevrolet Camaro 2LT/RS (sold)
2013 Hyundai Genesis Coupe 2.0T (sold)
2010 Chevrolet Camaro 1LT (sold)
2007 Dodge Charger SRT-8 (sold)
2007 Cadillac CTS (sold)
2005 Chrysler Sebring (sold)
1998 Dodge Avenger (sold)
1992 Mercury Topaz (sold)
xmattyx is offline   Reply With Quote
Old 04-15-2018, 10:54 AM   #24
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
This was happening on a different GM car when it was new.
I never had to disconnect the battery.
You need to shut off the car, and open and close the door to disable RAP. Then wait at least 10 minutes and start the car again.
This worked for me, but when the problem recurred I called OnStar and they were able to reset the system remotely. The problem didn't recur after that.
