Old 12-17-2015, 01:58 PM   #1
xk49
xk49's Avatar
Drives: 2011 2SS/RS L99 RJT Convertible
Lifter Upgrade: And Cam?
I currently have an Eforce SC, Rotfab and headers as my performance upgrades. I've heard concern about lifters being an issue, so I thought I would get those replaced, but I was thinking that since there's a bunch of crap that needs to be pulled for the lifters, why not do a mild cam as well.
My worry is if I do the cam that I'll need to do injectors(running the Eforce kit 52lbs injectors currently), rails, pump, etc. or can I just do the cam and de-tune the car.
Basically, if I have to have the engine partially pulled apart for the lifters, what can I have done for future stuff without replacing the whole fuel system at the same time. (fuel system next year).
Flowmaster Force II Axle back, Kooks LT's and Highflow Cats, Oracle Side Makers, BC Coilovers, E-Force Supercharger, Rotofab Intake, HexVents, ACS T4 Splitter/Rockers/Wind Deflectors, Aeroforce dual pod, Autometer boost/WB analog gauges, MRR M228 20x10 20x11 Nitto Invo 275/315's, CDC Sport Bar, Tuned by Slowhawk Performance.
xk49 is offline   Reply With Quote
Old 12-17-2015, 06:53 PM   #2
1985airborne
One Slow Automatic
1985airborne's Avatar
Drives: 2017 GS 2010 CAMARO SS
I just bought johnson lsr 2116 just to be safe; any future builds i will use johnson.
650HP 2010 CAMARO SS 710HP 2017 GRAND SPORT
1985airborne is offline   Reply With Quote
Old 12-17-2015, 06:56 PM   #3
Nighthawk89
Nighthawk89's Avatar
Drives: 2011 Camaro 2Ss M6
Without you telling me your power level my guess you are in the low 500 range so i wouldn't worry much. Im low 600's right now and I just went with the full BTR Stage 3 PD Blower cam setup (Will be installing in the following weeks).
With that being said i would worry about your fueling now and then work on the cam and additional upgrades after. Id go with a fueling supply that serves more then what you may desire. (Dual Pump, Lines, 85lb or 1000lb injectors, ECT.)
Nighthawk89 is offline   Reply With Quote
Old 12-17-2015, 07:49 PM   #4
hammdo
'It's an experiment'
hammdo's Avatar
I did the ZL1 fuel pump and ADM FPCM. That will do for me up to about 660 RWHP. I do have the ZL1 LSA conversion.
-Don
747 RWHP 794 RWTQ
Old 12-17-2015, 10:45 PM   #5
LSX Camaro
Master ASE, GM, LSX Tech.
LSX Camaro's Avatar
Drives: 2010 Camaro SS
Always Johnson lifters and BTR valvetrain components.
2010 2SSRS A6, Custom Pat G. Cam, WCCH Cylinder Heads, Kooks Headers/Exhaust, BTR Valvetrain, Fluidampr 25% UDP, All Engine ARP bolts, Flex-a-lite radiator/Trans cooler, Yank converter, PFADT Suspension, ADM Race Intake/Scoop, Torq tow hook, CFD auto shifter, Dynojet AFR gauge, Aeroforce scan gauge, Brake Performance rotors/pads
Prothane bushings, ZL1 wheels, spoiler, Z/28 wickerbill, 1LE Aero/Suspension Package, Anderson Composites COPO Carbon Fiber Hood, LED lighting, Elite Catch Can, Improved Racing oil pan baffle, crank scraper, windage tray
480 RWHP 452 RWTQ + Nitrous Express 150 Shot
LSX Camaro is offline   Reply With Quote
Old 12-18-2015, 10:51 AM   #6
xk49
xk49's Avatar
So, are you recommending the fuel first as that won't help me address the immediate problem of the lifters.
Old 12-18-2015, 12:18 PM   #7
JDP Motorsports
JDP Motorsports's Avatar
Drives: 2011 Camaro SS/ 2016 Camaro SS
I would do a camshaft package and get a set of ID-850 injectors for the time being. Then you can upgrade your fuel system next year and up the boost. The camshaft depending on the selection is going to bleed pressure or boost. I'd go with the BTR Stage 2 PD camshaft that is used in THIS package.
Please feel free to call, email or PM us anytime with questions. Good luck and have a great weekend.
Kind regards,
Jordan Priestley
888.308.6007
JDP Motorsports is offline   Reply With Quote
Old 12-18-2015, 06:33 PM   #8
Nighthawk89
Whats your immediate concern with the lifters? I can understand your concern for your stock internals but there are many pushing a lot more without any issues. Depending on your budget i Would go fueling first and then go cam but thats just me. I had a buddy who did it backwards and maxed out his fueling supply on a cold morning and got on it and Kaboom went his engine. Instead of trying to max out your fueling supply id just get it knocked out of the way and then go for the cam upgrade and the top end benefits the cam packages provide.
