AWE Tuning
Old 03-15-2024, 02:17 PM   #15
m6-lt1
m6-lt1's Avatar
Drives: 2023 Chevrolet Camaro 2SS 1LE
Originally Posted by LateBrakeU2 View Post
Owned both, the voodoo has the consumption issues( take a look on shelby threads, you would be concerned on the #s) and it makes very little power under 3k. I would venture a 1LE is quicker on most road courses .
Did yours consume oil and was yours a 19+? Did Ford take care of you when you reported it?
Current: 2023 2SS 1LE
Prior:
2016 Camaro 1SS
2007 Mustang GT
2008 Civic Si
m6-lt1 is offline   Reply With Quote
Old 03-15-2024, 07:39 PM   #16
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
Have you considered a Mach 1? I have been looking at them a lot myself, and the 1LE as well.
You mention not caring about handling, so the downgrade in that area may not be a negative for your use case.
Limited Edition, but not a 'special' engine, Coyote is still great and arguably much more reliable than the Voodoo. Also gets the great Tremec M6, and sounds great.
I think it would give you a less settled platform in the sense it would be more fun to drive on the street.
A used 2023 isn't too far off in cost to your 2SS as a ZL1 would be, but it isnt a GT350 either.
Old 03-15-2024, 07:57 PM   #17
m6-lt1
m6-lt1's Avatar
I consider the 03/04 Mach 1 a special car because it got a bespoke engine but not the 2021+. It’s just a coyote with a gt350 intake manifold added. However now that you mention it the non handling pack Mach 1 might be an option so I’ll add that to my list. Mach 1 handling pack=SS 1le so I think I would find the “better” car boring on the road kind of like I find my SS 1le. It’s probably much easier spinning the tires in a non handling pack Mach 1.
What’s appealing about coyotes is they are far more robust when adding a bunch of power than the voodoo/Lt1. Don’t have to worry about piston ring end gaps kissing in them.
Prior:
2016 Camaro 1SS
2007 Mustang GT
2008 Civic Si
Old 03-15-2024, 08:06 PM   #18
Dabjbr
Drives: 2020 SS 1LE
Hey just throwing this out there… if you drive in track mode and find it boring, switch to sport instead. Track mode makes the throttle more linear and some might feel like it’s less powerful.
Dabjbr is offline   Reply With Quote
Old 03-15-2024, 08:42 PM   #19
CTRifecta
CTRifecta's Avatar
Drives: 2SS 1LE
imo keep the 1LE and just track it / drive it more spiritedly but safely of course.
the mustang chassis and steering is just subpar in terms of quality but also capability vs. the camaro, and that alone makes it a non-starter. Sure that gt350 5.2 motor is amazing, but it's far less proven / reliable compared to the 6.2 LT1.
On the flip-side, if all you care about is straight line acceleration / sound, gt350 could be more suited to you.
2024 2SS 1LE | 6MT | Riverside Blue
1100 - Order submitted - 7/12/23
2000 - Order accepted - 8/22/23
Vehicle Built (per chevy chat bot) - 10/10/23
Window sticker available online - 11/4/23
Arrived at dealership - 11/10/23
CTRifecta is offline   Reply With Quote
Old 03-15-2024, 09:05 PM   #20
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
The Tremec and the Coyote combo is a real good one. The not so special nature also helps with price from what I have been seeing.
Old 03-15-2024, 09:11 PM   #21
Kezos
Kezos's Avatar
Drives: 22 1SS 1LE
I've driven mine friends 2017 gt350 a bit and done some autox runs in it. I do love the sounds it makes. And he does outrun me in a drag race. Autox my camaro is always alittle quicker, would like to do laps back to back on a road course with them to see how it feels and times to my 1le. But i do prefer my ss 1le overall to it. The Camaro just feels better to me in all aspects. But it is a great car forsure.
2022 1SS 1LE M6 Summit White
Kezos is offline   Reply With Quote
Old 03-15-2024, 09:24 PM   #22
Curr
Probably doesn't like you
Curr's Avatar
Drives: 2022 WCT ZL1 M6
Yeah just the oil pump gears and crank sprocket letting go. Or maybe the AC goes?
Coyotes arent immune to issues either.
I hope the 6th gen Camaro has a melodious horn trumpet. I'll tootel it at the ladies, yelling out "Hi hi." - RenegadeXR
كافر
ΜΟΛΩΝ ΛΑΒΕ
железобетонное очко
Quod gratis asseritur, gratis negatur.
There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly.
Curr is offline   Reply With Quote
Old 03-15-2024, 11:43 PM   #23
m6-lt1
m6-lt1's Avatar
While I have driven it in sport, the last few weeks I threw it in track to see if it felt more fun. Unless I’m not remembering correctly, my standard SS in track mode from 3500 rpm would pull real hard when I stepped on it. The 1le however feels way slower/more tame. I am going to try it out again in sport next week. I was wondering if the throttle mapping is different between the standard SS and the SS 1le. I have turns all the Nannie’s off in case that was the issue.
Prior:
2016 Camaro 1SS
2007 Mustang GT
2008 Civic Si
Old 03-16-2024, 01:58 AM   #24
Dabjbr
Drives: 2020 SS 1LE
More info here…
https://www.camaro6.com/forums/showthread.php?t=554014
Old 03-16-2024, 04:54 AM   #25
ariZona28
Give speed a chance
ariZona28's Avatar
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28
Someday (just not TO-day) I'll figure out how to post videos. Until then a screenshot referral will have to suffice. Check out this fellow as he demonstrates proper SS 1LE rowdiness. This guy is a hell of a driver in whatever he pilots but you get a pretty good idea of the 1LE capabilities. Those familiar with AZ Motorsports Park know that a 1:44 lap is SMOKIN' quick! YouTube, Eric Kennel.
ariZona28 is offline   Reply With Quote
Old 03-16-2024, 06:43 AM   #26
Gen6cyl
Gen6cyl's Avatar
Drives: Chevy Camaro 2021 ,rs, v6, manual
I know y'all have heard of that throttle control thing that makes the throttle very aggressive.
B6 dampers, x pipe, mbrp axel back
Gen6cyl is offline   Reply With Quote
Old 03-16-2024, 07:16 AM   #27
arpad_m
arpad_m's Avatar
Drives: 2018 Camaro 2SS A8
I don't think track mode throttle mapping would be different between the SS and the SS 1LE by default, but you should try the different PTM modes before concluding the 1LE is slower or more tame.
Is it possible you're remembering sport mode in the SS? I'm asking because track mode on my SS has perfectly linear pedal mapping, and we easily get desensiitized by sport mode where early pedal travel matters much more, e.g. 25% TPS translates to opening the throttle blade to at least 50-60%.
735 rwhp | 665 rwtq
3000 - 2/06/18 TPW 2/26/18
Old 03-16-2024, 07:47 AM   #28
m6-lt1
m6-lt1's Avatar
Is it possible you're remembering sport mode in the SS? I'm asking because track mode on my SS has perfectly linear pedal mapping, and we easily get desensiitized by sport mode where early pedal travel matters much more, e.g. 25% TPS translate to at least opening the throttle blade at least to 50-60%.
I’m 99% sure whenever I did highway pulls in my 16, if I did it in track from 3500 rpm it pulled harder than sport. Maybe it’s placebo? Sport mode felt better down low and I still feel sport mode feels better down low in the new car.
I tried ptm sport 2 and track to see if I could get it to be rowdy. Also I’m on all seasons. Granted they have full tread but I’m shocked it can’t spin the tires in first from a roll. Sometimes I can get them to spin only if I go WOT right where the LT1 makes peak torque. I never “have fun” until the tire temp indicator has been blue for a while or I usually wait till green. I used to wait awhile in my 16 as well because I don’t think it’s safe to go wot on cold tires.
Prior:
2016 Camaro 1SS
2007 Mustang GT
2008 Civic Si
