TireRack
Old 12-19-2018, 10:04 AM   #1
Sturgill_SS
Sturgill_SS's Avatar
Drives: 2010 Camaro SS
Best Intake for Rolls?
Getting ready for next season and looking to upgrade my intake. I was looking at a high ram but there are complaints that you lose low end torque. What are your opinions? Set up with an f35 stage 4 cam
F35 Cam / LOD X-1 Manifold / SLP CAI / LS7 Lifters / 3.91 Gears / Hooker Blackheart Exhaust / TSP Headers / SLP Underdrive Pulley / MGW STS / Trunnions and all that other fun stuff....
Sturgill_SS is offline   Reply With Quote
Old 12-20-2018, 05:25 AM   #2
jman17
jman17's Avatar
Drives: 2011 SS-2/1969 SS
Stick with a stock intake manifold, you can't beat it.
1969 SS: SS/DA 427 CI/Auto
2011 SS-2 LS3 M6 MODS: P1X ProCharger, Squash dual fuel pumps, ID fuel injectors, Cam: Pat G designed/EPS Ground (228/234 .629”/.629” 114 LSA +4 advance), Lethal Racing ported throttle-body and intake manifold, Kooks 1 7/8” Long Tube Headers, Dynomax Bullet Cat-Back System, Skip Shift Eliminator
jman17 is offline   Reply With Quote
Old 12-20-2018, 08:12 AM   #3
jergarr
jergarr's Avatar
Drives: 11' RJT 2SS/RS L99
Look into the GPI rod mod. They install radius bars in the intake as well as porting. They also have the option to add a heat shield to it. I should be getting mine back in the next couple weeks as they are doing all of the above mods to it. I should have this all installed and retuned by spring and I'll share the results.
GPI VVT3 Cam
Circle D 3800 Single Disc Stall
1LE 3.91s
Stainless Power Headers w/cats
Fluidampr 25% UDP
Cold Air Inductions Intake
Bo White Ported Throttle Body
ADM Trans Cooler
Some BMR Goodies
jergarr is offline   Reply With Quote
Old 12-20-2018, 08:14 AM   #4
xc_SS/RS
Drives: 2010 Camaro SS/RS
Mid runner fast or take a look at the LOD speedworks manifold. Stock intake manifold is pretty limited past 6500 RPM and the F35 stage 4 cam power peak is at 6600 rpm
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 12-20-2018, 08:15 AM   #5
jergarr
jergarr's Avatar
Here's the link to their website.
https://gwatneyperformance.com/product/ls3-intake-mod/
GPI VVT3 Cam
1LE 3.91s
Fluidampr 25% UDP
ADM Trans Cooler
Some BMR Goodies
Old 12-20-2018, 08:21 AM   #6
Roader
Drives: Camaro
I had a stock ported/rod mod and it did well with a ss4. I upgraded to super Vic and picked up hp but lost tq. Pick your poison
Roader is offline   Reply With Quote
Old 12-20-2018, 09:10 AM   #7
Juiced1
Drives: 2012 2SS CAMARO 45th
You are going to lose your low end torque with that cam. If you want a big cam you are going to shift your power band way up the power band. The F35 stage 4 cam is a beast but it starts pulling at 4-4.5k. You'll need a stall of at least 4k on an auto or big gears on a manual. We'd install it for you or sell it to you if you want it but you have to keep in mind that it's no longer a street car. That cam would work great with a hi ram intake but would probably work great with a Fast intake or a ported stocker too.
Old 12-20-2018, 09:54 AM   #8
bkevind
bkevind's Avatar
Drives: 2013 2SS RS 1LE
I love a good roll stuffed with gravy, mashed potatoes and fried chicken breast or chicken fried steak...
468, Mishimoto rad + oil cooler, TSP LTH
MCS 2WNR
CTSV/ZL1 front calipers/rotors + G-Loc
Forgestar CF-5 19x11
bkevind is offline   Reply With Quote
Old 12-20-2018, 10:35 AM   #9
Roader
Drives: Camaro
I'd disagree. I'm running a big cam, 3.91s and around 5k stall. Fun on the streets if I'm smart about what I'm doing
Old 12-20-2018, 11:22 AM   #10
62nalide
62nalide's Avatar
Drives: 2013 SS
Keyword is Rolls as in roll racing. If this is a M6 run a ported High rise with a 102mm. Your low end will suffer but if your main focus is rolls thats your best bet.
62nalide is offline   Reply With Quote
Old 12-20-2018, 12:45 PM   #11
SSBUSDRVR
SSBUSDRVR's Avatar
Drives: '11 2SS/RS IBM/BLK M6
This
Old 12-20-2018, 01:47 PM   #12
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
LOD Speedworks FTW!!
Get one of these...
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 12-20-2018, 03:25 PM   #13
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
Here is some good data on what happens to the torque curve with a short runner intake, after 6K it starts to work.
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
zz430camaro is offline   Reply With Quote
Old 12-20-2018, 06:26 PM   #14
Sturgill_SS
Spoke with GPI today. Looks like their ported / rod mod may be the way I go. You see gains in the entire power curve. I'm also debating on the ported high rise. Decisions! It is an M6 car.
