Vararam
Old 12-05-2018, 07:15 AM   #1
Morgan.13
Drives: 2011 camaro 1ss
Trying to get more out of my set up
Looking for some recommendations for parts to help squeeze a little more out.
Current set up
Lethal racing night fury cam
(Supporting parts,Hv oil pump, timing chain, springs, titanium retainers, pushrods, etc)
Long tube headers
Flowmaster 3” exhaust
Af dynamic intake
I was considering the rod mod for the intake manifold and possibly porting the throttle body. Just looking for feedback/recommendations.
Car put down 441hp on a mustang dyno.
Morgan.13 is offline   Reply With Quote
Old 12-05-2018, 07:36 AM   #2
Avenging Orange
Avenging Orange's Avatar
Current set up
Long tube headers
Af dynamic intake
Attachment 966847
How about a set of 3.91's.
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 12-05-2018, 08:09 AM   #3
Morgan.13
I was considering the GM set, not sure how much of a pain in the butt it would be to pull the dif..
Old 12-05-2018, 09:56 AM   #4
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
Is it an auto or stick?
zz430camaro is offline   Reply With Quote
Old 12-05-2018, 10:04 AM   #5
Morgan.13
Stick
Old 12-06-2018, 10:48 PM   #6
rdavis
Drives: 2012 SS
Do the 3.91's. You won't regret it. IMO there are absolutely no downsides at all. Very noticeable boost in acceleration, can still cruise at 80 on the highway. I can't imagine ever going back to the 3.45's.
2012 2SS/RS 6speed, Howards asa cam on 113lsa Stainless works LT's, NPP exhaust, Z28 Cai, 3.91 gears. Tuned by Blue Thunder 2 racing Lubbock Texas.
rdavis is offline   Reply With Quote
Old 12-07-2018, 05:15 AM   #7
Morgan.13
Great, because I just ordered the Gm kit last night! Hahah
Old 12-07-2018, 07:34 PM   #8
jergarr
jergarr's Avatar
Drives: 11' RJT 2SS/RS L99
Current set up
Long tube headers
Af dynamic intake
Attachment 966847
I feel your pain im in a similar situation lol. I actually just sent my manifold out to gpi today for rod mod, porting, and they're also adding a heat shield to it as well. Im also deleting my cats and resonator when i get the my manifold installed. If you haven't already definitely do 3.91 gears and a 25% udp.
GPI VVT3 Cam
Circle D 3800 Single Disc Stall
1LE 3.91s
Stainless Power Headers w/cats
Fluidampr 25% UDP
Cold Air Inductions Intake
Bo White Ported Throttle Body
ADM Trans Cooler
Some BMR Goodies
jergarr is offline   Reply With Quote
Old 12-07-2018, 07:41 PM   #9
anorman91
anorman91's Avatar
Drives: 2010 nightfury FBO S/C 2SS
I’m in a similar position , same set up . Although those are low numbers for that cam, you must be auto . I put on a Powerbond 25% UD and a hot tune and I’m at 505. 3.91 is my next step
Are you chasing a number or time on the strip?
anorman91 is offline   Reply With Quote
Old 12-07-2018, 07:50 PM   #10
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
Your setup is very similar to mine! GPI FTW!
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Old 12-07-2018, 07:57 PM   #11
Morgan.13
M6 car, car was street tuned and then I brought it to another shop to have it dyno’d. I definitely had higher hopes number wise. Maybe bringing it in for a new tune on 93 this spring depending what I do this winter. I lean more toward the strip as that’s a true test of what the car can do haha. My fastest time was 12.6 in the 1/4. Each pass was getting faster my last night at the strip, just need more passes to dial in the drivers mod haha. Was yours dyno’d on a mustang dyno or dynojet?
Old 12-07-2018, 08:00 PM   #12
Morgan.13
Also ordered some 17” racestars today for the rear, now to decide what tire to run.
Old 12-07-2018, 09:04 PM   #13
jergarr
jergarr's Avatar
GPI VVT3 Cam
1LE 3.91s
Fluidampr 25% UDP
ADM Trans Cooler
Some BMR Goodies
Old 12-07-2018, 09:08 PM   #14
jergarr
jergarr's Avatar
I bought a pair of 17 x 9.5 racestars for the rears on black friday. Ill be running 28 x 10 Hoosiers come summertime.
GPI VVT3 Cam
1LE 3.91s
Fluidampr 25% UDP
ADM Trans Cooler
Some BMR Goodies
