dave@hennessey
Old 12-07-2018, 06:49 PM   #29
brick59
Sucker Punch
brick59's Avatar
Drives: 2013 Black ZL1, 2007 Silverado LTZ
Kooks 2" Ceramic coated.
427 Dart SHP Pro LS Block, Callies Magnum Crank, Callies Ultra I Beam Rods, Diamond Pistons, AGP twin Turbos 6865, Mast heads, Cam Motion LLR cam, Morel tie bar lifters, Crower roller rockers, NW 103MM TB, ID2600 XDS, Fore Triple, DSX, E85, ARH Turbo Headers, Corsa, Jakes stage 5 4L80, Circle D, RPM Roll Bar, BMR, Carlyle Racing 15" conversion kit.
brick59 is offline   Reply With Quote
Old 12-07-2018, 07:13 PM   #30
jergarr
jergarr's Avatar
Drives: 11' RJT 2SS/RS L99
Stainless Power with high flow cats. I'll be deleting cats this winter though.
GPI VVT3 Cam
Circle D 3800 Single Disc Stall
1LE 3.91s
Stainless Power Headers w/cats
Fluidampr 25% UDP
Cold Air Inductions Intake
Bo White Ported Throttle Body
ADM Trans Cooler
Some BMR Goodies
jergarr is offline   Reply With Quote
Old 12-07-2018, 09:50 PM   #31
bkevind
bkevind's Avatar
Drives: 2013 2SS RS 1LE
Originally Posted by bkevind View Post
TSP. So far so good.
To clarify I've got TSP 1 7/8 with x-pipe, then all the way back to the axle, connected to NPP (fuse pull). It's freakin' loud, especially under load over 2500, and really especially at full throttle...wow.
468, Mishimoto rad + oil cooler, TSP LTH
MCS 2WNR
CTSV/ZL1 front calipers/rotors + G-Loc
Forgestar CF-5 19x11
bkevind is offline   Reply With Quote
Old 12-08-2018, 05:57 AM   #32
KickerZ71
KickerZ71's Avatar
Drives: Camaro SS
Kooks 1 7/8 headers with high flow cats, and solo Mach x exhaust
KickerZ71 is offline   Reply With Quote
Old 12-08-2018, 06:47 AM   #33
John_C
LSx FTW!!!
John_C's Avatar
Drives: 2010 Camaro 2SS RS
Kooks Jet Hot Ceramic Coated
Full Kooks true 3in all the way..
2010 2SS RS A6 781rwhp on E85
Stage 2 ProCharger D1X
Circle D 3400 Triple Disc
Kooks Jet Hot Headers
Kooks Full 3in exhaust
Trick Flow GenX 255's
Polished PAC .660's & Ti-retainers
TSP VVT 3.2 cam kit w/DoD Delete
Smith Bro's Trunnion kit
AEM X-Series OBDII Widebands
FIC ID1300x Injectors
GM ZL1 High Output Fuel Pump
DSX Tuning Flex Sensor
DSX Auxiliary Fuel System
Tim King Stage 4 Max Effort CTSV 6L90
DSS 1 piece aluminum driveshaft
JRE 6L80E / 6L90E Dipstick
NGK Iridium IX spark plugs #7 heat range
Mighty Mouse Camaro 5 Wild w/-12an and Billet Black
HP Tuners VCM Suite
John_C is offline   Reply With Quote
Old 12-08-2018, 08:36 AM   #34
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
If you think its loud now, wait till you cam it.
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Old 12-08-2018, 08:55 AM   #35
LCPLPunk
USA-1
LCPLPunk's Avatar
Drives: 2010 Camaro SS L99
Speed Engineering.
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete
LCPLPunk is offline   Reply With Quote
Old 12-08-2018, 09:23 AM   #36
rontammy0
Drives: 2011 2SS/ RS INFERNO ORANGE L99
I would like to know what setup is louder then my Stainless Power 1 7/8 catted longtubes bolted to the Corsa Xtreme catback. According to people behind me or beside me while driving....its ear splitting.
rontammy0 is offline   Reply With Quote
Old 12-08-2018, 09:48 AM   #37
Chris49066SS
Drives: 2010 SS L99
Mine, with all due respect sir. Just take your cats/catback off and you'll see what I mean. Having a big cam helps a lot too. It got way louder when that thing went in.
Old 12-08-2018, 11:00 AM   #38
George-CZ
George-CZ's Avatar
Drives: 2010 2SS LS3 and 1978 STROKER 383
Sounds very nice.
I like it.
George-CZ is offline   Reply With Quote
Old 12-08-2018, 11:08 AM   #39
George-CZ
George-CZ's Avatar
Stainless Power and high flow cats from DynoSteve, H-pipe and modified Italian Ragazzon mufflers.
...it does not sound bad.
Old 12-08-2018, 11:44 AM   #40
bkevind
bkevind's Avatar
Ah man I don't want it any louder lol. But definitely want to cam it. I want the GPI Max package or similar. with COTA in my neck of the woods, I have to at least put up a fight on the long straights with those pesky new cars with bajillions of powers. I know I could boost it for similar(ish) money and more power but...I want to stay NA and have a reasonably balanced package overall. Besides, heat management for 20 minutes at a time of brutal abuse is hard enough without the added heat of boost.
Though the truth is for a track (road course) car you really don't need huge power. It's all about grip and driver skill. I just want more for the fun of it, and it helps recover from mistakes aka it's a way to set pretty good lap times and still be a so-so driver.
I just think the car needs more power for it's sound, it's look - it just doesn't have enough bite to go with it's bark the way it sits.
MCS 2WNR
Old 12-08-2018, 12:11 PM   #41
Steves ss
Steves ss's Avatar
Drives: 2010 Camaro SS/RS Black
American Racing Headers. Un coated. Raw stainless steel.
Steves ss is offline   Reply With Quote
Old 12-08-2018, 01:09 PM   #42
Chris49066SS
Drives: 2010 SS L99
That sounds fair enough! The GPI Max Package does look good. I would've liked to get it, the budget just wouldn't quite allow it this year.
