Old 06-24-2020, 08:43 PM   #1
CodeRev
Drives: 2020 Camaro LT1 ( A10 + NPP )
Clueless on tire/wheel fitment options for 2020 LT1 ( 20" wheels w/ 245's run flats )
Just join the Camaro crew in April. I purchased an 2020 LT1. Of course you all know, it comes with stock 20" wheels w/ 245 run-flats. I do not mind the run-flats now. But, I want to start saving for bigger wheels and/or tires.
My questions are:
- What fitment options do I have currently without needing modifications?
- The stock tires are 245's I believe. Can I go with a larger size now?
- If I go with 305's, I heard there is a wiring harness issue in the rear, you must take care of first. Is this true with the 2020's?
Much appreciated!
CodeRev is offline   Reply With Quote
Old 06-25-2020, 06:47 AM   #2
VinnAY
Drives: 18 1SS/1LE
2020 LT1 tells us nothing about the diameter and width of the wheels that you have. The range of tires sizes is based on that. On the width of a wheel you can really go up ~two sizes, safely. 245 > 255 > 265. Wheel widths specify tire width's that are appropriate or "safe".
If you have a wheel with a 245 on it you cannot put a 305 on it.
VinnAY is offline   Reply With Quote
Old 06-25-2020, 07:02 AM   #3
CodeRev
Thank you for the information. My fault for being vague.
20" wheels w/ 245's square set-up All-season run flats, is what I have currently.
Old 06-25-2020, 07:28 AM   #4
VinnAY
Drives: 18 1SS/1LE
Typical size situation a 245 tire mounts to a 9.5" wheel, I would assume that that's what you've got for an OE setup. With a 9.5" wide wheel you can go up to 255 or 265, 275 would be the max recommended tire width for that wheel.
https://www.tyresizecalculator.com/c...rim-size-chart
camaro 2020, lt1, tire, wheel
