02-12-2015, 10:41 AM | #1 |
Drives: Supercharged 2013 2SS/RS Join Date: Sep 2013
'13 SS L99 vs '06 6.0 GTO
Friend of mine just picked up a 6.0 GTO auto. He wants to run me before he trades it for a truck. Who do you think will run from a dig 1/4 and 40,60,70 roll?
02-12-2015, 12:37 PM | #2 |
Drives: 2010 SS, 2000 Pontiac Formula Join Date: Mar 2013
I'm giving it to the GTO, but should be a good race. Whoever gets the jump will probably win if both are stock.
02-12-2015, 01:38 PM | #3 |
Drives: C6 Corvette Join Date: Sep 2013
Theres no way that GTO should win. It weighed the same with less power. Both cars auto.....You should walk away from that GTO no problem
2008 C6 m6. Carbon creations front/rear carbon fiber wodebody fenders. Carbon fiber hood carbon fiber roof hoop carbon fiber zr1 extreme spoiler. NW 102mm tb. Ported intake manifold. Cometic .040 head gaskets. LG motorsports G6x3 cam. DSX flex fuel sensor. AEM methanol kit. Z06 brakes. Ebiach sway bars. ZR1 rep wheels and Nitto Invo tires. Monster stage 3 twin disc clutch. MGW short shifter. Corbeau race seats. Gforce race harnesses. SLP loudmouth 2 mufflers. Carbon fiber exhaust tips. RPM stage 4 transmission and Stage 3 rear diff. 3.73 gears. Vararam cai. Kooks 1 7/8 headers and x-pipe.
02-12-2015, 01:42 PM | #4 |
Nightmare
Drives: Your mom crazy in bed Join Date: Mar 2011
The GTO should lose every time, unless you launch poorly. The best times on the GTO were around mid 13's....so it should lose, but not a huge blow out.
02-12-2015, 01:46 PM | #5 | |
Nightmare
The GTO's were weighing in around 3700lbs, so just about 100lbs lighter than the Camaro... The GTO also produced 400hp and 400lbs of torque....so again... pretty much the same stats. The difference however is that very crappy transmission in the GTO...
02-12-2015, 02:47 PM | #6 |
Drives: 16' 2SS M6 Join Date: Feb 2010
GTO has that 4 speed slush box and gets lots o' heat soak. Kick his azz!
02-12-2015, 03:19 PM | #7 |
Drives: 13' 1LE Join Date: Apr 2012
Should be close but you have him.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
02-12-2015, 03:20 PM | #8 |
Nightmare
^^^^^^^^^^^This!
02-12-2015, 08:32 PM | #9 |
Drives: 2011 2SS/ RS INFERNO ORANGE L99 Join Date: Dec 2012
Camaro for the win.
02-12-2015, 11:06 PM | #10 |
Drives: 2008 VW R32, 2011 Synergy Green 2SS Join Date: Jul 2010
You should beat the GTO. But the real question here is, why did your friend just pick up a GTO when he is now talking of trading it for a truck? Why not just buy the truck in the first place?
02-12-2015, 11:33 PM | #11 |
He gets good deals on cars the resales them for a lot more than he paid. He does a few thing to it like, paint, rims, etc, makes it look like it's worth a lot for cheap and he makes money like that.
02-13-2015, 06:36 AM | #12 |
Philippians 4:13
Drives: SLP Supercharged LS3 Join Date: Aug 2009
I had an 05 GTO auto. I took it to the track one time when it had 400 miles on it. I only made 2 passes. Both were 13.40's @ 105.XX. Based on that i think it may have had a little more in in with better 60 ft and cool down. Not sure how that compares to a stock l99.
02-13-2015, 06:13 PM | #13 |
Drives: 2013 A6 GT 5.0 Join Date: Nov 2009
If you were to compare fast list it will tell you that the two cars are seriously super close. The top 20 fastest stock LS2 GTO's range from 13.0-12.6 with the fastest A4 GTO at 12.8 (nearly the same as L99) I think if you put DR's on both cars the GTO would be nearly identical to the L99. It suffers from a seriously small tire and poor suspension from the factory meaning stock for stock it takes a better driver out of the GTO and/or a stickier track than it does out of the L99. Put the 6L80E trans into the GTO and it would smoke L99's. In other words the only thing that keep it close is traction, gearing and shift recovery. GTO's have a piss poor exterior design for the name it carries but they can run pretty well.
BLK/BLK 1SS/RS Ordered 11-01-2009 Took delivery 12-22-2009. Heads/cam/converter/bolt ons. SOLD Feb 2015 to fund 6th gen LT1 SS with 8L90E.
02-13-2015, 10:48 PM | #14 |
Drives: 2013 Camaro ZL1 Join Date: Oct 2012
GTO wins. Sorry
