09-26-2022, 08:36 AM | #15 |
The drive mode selector does not alter the suspension properties of the 1LE, but all my runs so far have been in Sport, but it feels faster day-to-day in Track.
'20 ZL1 1LE A10.
LME 390, E2650, FBO, 100 oct. Not a DD. |
09-27-2022, 09:21 PM | #16 |
Drives: 98 Camaro Join Date: Apr 2022
Sport mode for sure on my Lt1 trim car. I noticed lazy 1-2 shift under wot in touring. Sport mode quickened the shift up and almost a tenth quicker in 1/4
09-28-2022, 06:50 AM | #17 |
Im sure he meant to say ZLE
09-28-2022, 07:45 AM | #18 |
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | LS MSD Plug Wire Set | DOD Delete | BTR Stage I Cam | ECM, TCM & E85 |Retuned by: Justin L. | Dyno: 510 rwhp 472 rwtq
07-26-2023, 08:19 AM | #19 | |
It's detailed here https://www.camaro6.com/forums/showthread.php?t=496996
'20 ZL1 1LE A10.
LME 390, E2650, FBO, 100 oct. Not a DD. Last edited by JSH; 07-26-2023 at 08:30 AM. |
07-26-2023, 10:07 AM | #20 | |
07-26-2023, 10:36 AM | #21 | |
I don't think there's a measurable difference. I only focus on going straight.
'20 ZL1 1LE A10.
07-26-2023, 11:51 PM | #22 | |
07-30-2023, 07:27 PM | #23 | ||
Double Tap TC Off = Stabilitrak still on. (Keeps the car going straight if the rear tires break loose on a straight a way.) Quote:
07-30-2023, 08:54 PM | #24 |
snow/ice
you will thank me later
2023 Camaro ZL1 Vert TR-6060 Sharkskin "Sharky"
Firecracker Red Wrangler Willys, 3.6L eTorque, 850RE 8 speed automatic, 25W Willys package, Technology Group, Convenience Group (aka $600 garage door opener), Cold weather Group, Trailer Tow and HD electric group with AUX switches, 3 piece black freedom top. |
07-31-2023, 08:37 AM | #25 |
Drives: 2021 LT1 6spd Join Date: Nov 2020
Fran knows what he is talking about. Ice part means you'll have ice on your wrists after winning.
Current: 2021 LT1 Camaro, 6spd, Crush, Corsa NPP, GMPP CAI, Soler Performance Throttle controller
Previous: 1997 V6 Camaro, 5spd, Black |
07-31-2023, 08:32 PM | #26 |
Drives: 2019 Camaro 2SS Join Date: Aug 2020
When I bump into track (from sport) at 35-40mph it seems to drop a gear (or maybe unlocks the converter?) so I think there is some effect on transmission shift logic, but I’ve never seen the info on differences between modes regarding the A10.
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
07-31-2023, 08:46 PM | #27 |
I believe it. My five runs were all in sport with nannies off. Haven't made any hits in track but I will the next time with TC off and stability track on.
'20 ZL1 1LE A10.
