BeckyD @ James Martin Chevy
Old 05-18-2017, 12:09 AM   #1
'68-'88-'01-'10-'17
2017 ZL1 HBM / 2010 2LT
'68-'88-'01-'10-'17's Avatar
Drives: '68, '88, '01, '10, '17 Camaros
Underbody Air Deflector Tire Dam Kit
I have a question: in the high performance owner's manual supplement, on page 17, it says:
The underbody air deflector tire dam kit provided with the ZL1 vehicles reduces the amount of aerodynamic lift on the front axle for better handling. The original tire dams must be reinstalled after the track event. For installation, see the instructions provided with the kit.
Does this mean that the car should have come with a separate kit? Ours only has the ones originally installed on the car, but this quote makes it sound like a special kit should have come with the car to allow you to switch them out.
I am trying to figure out I need to go back to the dealer to get the missing kit, so I would appreciate any feedback from other ZL1 owners
Thanks in advance for any information!
'68 Camaro, owned since '83 - '88 IROC Camaro, owned since '95 - '01 Camaro, owned since 07/05/01 - '10 2LT/RS IBM/CG Rally stripes, ordered July 2009, arrived 09/09/09, and our newest babies:
TXXRJG - 2017 ZL1 / Hyper Blue / A10 / Sunroof, etc. - Ordered - 08/12/16, Delivered!! - 03/16/17
And the latest addition: 2017 2LT / RS / Garnet Red / A8 / delivered 05/25/17
'68-'88-'01-'10-'17 is offline   Reply With Quote
Old 05-18-2017, 12:20 AM   #2
NightfallZL1
NightfallZL1's Avatar
Drives: 2017 nightfall zl1
NightfallZL1 is offline   Reply With Quote
Old 05-18-2017, 01:41 AM   #3
Android42019
The Black Emerald
Android42019's Avatar
Drives: '17 ZL1, '08 Trailblazer, '11 1LTRS
Hmmmmm...subscribed.....
Android42019 is offline   Reply With Quote
Old 05-18-2017, 02:02 AM   #4
mr965
mr965's Avatar
Drives: ///M3
Mine came uninstalled and in the trunk. They said they would install it if I wanted. It came in two separate packages. One longer spoiler for the middle and the side pieces in a separate bag with fasteners.
mr965 is offline   Reply With Quote
Old 05-18-2017, 05:39 AM   #5
ZL*Won
ZL*Won's Avatar
Drives: 2017 Hyper Blue Metallic ZL1 A10
2017 ZL1 Hyper Blue A10
ZL*Won is offline   Reply With Quote
Old 05-18-2017, 05:46 AM   #6
HyperBlueX2
HyperBlueX2's Avatar
Drives: '22 Silverado 2500HD Duramax LTZ
The deflectors should have been installed during PDI..... you need to remove the large front ones for track days, and replace them afterwards.......
Here is another link about it.....
http://www.camaro6.com/forums/showth...nce+supplement
The third post by Inspector 17 has a pic and a great explanation.....
HyperBlueX2 is offline   Reply With Quote
Old 05-18-2017, 08:27 AM   #7
'68-'88-'01-'10-'17
Thanks for the info!
I looked under the car and it does appear that we have everything we are supposed to have - as you said, apparently the correct pieces were installed during PDI.
We are going back today to talk to the dealer about some issues and I just wanted to make sure we didn't need to add this to our list.
Thanks!
Old 05-18-2017, 09:43 AM   #8
KenB925
Drives: Raptor
I'm confused, if the deflector(s) 'reduces the amount of aerodynamic lift on the front axle for better handling' why would you take them off for a track event? Isn't that where you would want them the most (assuming road course as track)
KenB925 is offline   Reply With Quote
Old 05-18-2017, 09:54 AM   #9
Mr. Meh
Drives: Sold
You're not actually removing the deflectors (those channels) you're removing the blocking piece in front of them that doesn't allow air to channel through them as you're just driving along.
The curved channel bits are what move air from under the car to reduce lift. The straight edge pieces on each side are what come off for track.
Mr. Meh is offline   Reply With Quote
Old 05-18-2017, 10:04 AM   #10
HyperBlueX2
^^^^^ What Mr. Meh said ^^^^^
Old 05-18-2017, 10:27 AM   #11
KenB925
Drives: Raptor
Ok, that makes sense, the 'deflectors' probably help with fuel economy and removing them makes the aero work.
I would probably just leave them in the trunk if thats the case.
Old 05-18-2017, 10:34 AM   #12
Mr. Meh
Drives: Sold
Additional data here (with pics)
http://www.camaro6.com/forums/showthread.php?p=9732667
(which I see was also linked above)
Old 12-27-2017, 02:34 PM   #13
Sakudog
Sakudog's Avatar
Drives: 2019 ZL1 1LE A10
This thread confused me somewhat... this image cleared everything up for me.
Ryker #29
2019 ZL1 1LE A10
2015 Z/28 #809
Sakudog is offline   Reply With Quote
Old 12-27-2017, 04:39 PM   #14
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Drives: 16 SS & 17 ZL1 Both Yellow
Send a message via Skype™ to EDFHOBBIES
Not sure but on the SS those are removed when u install the big break kit when running the larger brake deflectors that hang about 3 inches from pavement I took those air dams off and left the larger brake deflectors on.
Wonder why we didn't get the larger ones in trunk for track days..
Kong Ported 2650, Crawford Racing Port Injection, Weapon X 112mm Adapter, NW112mm TB, Livernois Ported LT4 Heads, Lingenfelter GT32 stealth cam, Haltech Elite, and Carbon by Trufiber
EDFHOBBIES is offline   Reply With Quote
