10-05-2018, 10:03 PM | #1 |
2018 ZL1 1LE
Drives: 2018 ZL1 1LE Join Date: Aug 2017
How to store your car
Going in storage 11/1. Anything special you guys do to your Z before putting it away for the winter and do you use stabil? For you manual guys, do you leave your car in gear or do you use the ebrake or both? Thx!
10-05-2018, 10:45 PM | #2 |
Drives: ZL1 1LE SUMMIT WHITE Join Date: Feb 2018
I have the same questions. Mine's going into hibernation at the end of October in a heated storage unit.
Also... Lift on supports to give the tires a break? |
10-06-2018, 06:00 AM | #3 |
Drives: Sinister ZL1 Join Date: May 2018
Jack stands, battery tender, stabilizer in the fuel, oil change when she comes out in the spring... that's my plan.
Not sure what else is reasonable / realistic, but would love to hear other opinions!
2018 ZL1 A10
10-06-2018, 07:24 AM | #4 |
Thank you Al Oppenheiser!
Here's a few tips...
10-06-2018, 07:26 AM | #5 |
Flyin NOE
Drives: 2018 ZL1 (A10) Join Date: Apr 2017
1. Don't want to put it on blocks, the suspension is indexed to have weight on the wheels
2. Inflate the tires to 45 psi (and if you're paranoid lift the car once a month and rotate the wheels a quarter turn) so they won't flat spot. 3. Box or two of baking soda in the interior 4. Full tank of gas with stabil 5. Battery tender 6. Wash and wax her before you put a car cover on |
10-06-2018, 07:26 AM | #6 | |
Flyin NOE
10-06-2018, 07:43 AM | #7 |
2018 ZL1 1LE
This makes me wonder about the unsold cars, sitting on dealer lots during the winter months that are in cold climates. Except for the batteries that need to be charged are jumped sometimes, they seem to be okay when spring arrives.
On my Gen 3 Viper and it was never recommended to engage the ebrake unless absolutely necessary, even in storage. Sometimes the ebrake wouldn't fully release and therefore the pads would get unnecessary wear and could eventually create surface damage to the rotor. Always has made me a little concerned about using it on any car. Of course if you have a lift or use jack stands, it's a non issue. |
10-06-2018, 07:49 AM | #8 | ||
2018 ZL1 1LE
10-06-2018, 08:13 AM | #9 |
Flyin NOE
Leave it in gear, especially if you plan on rotating the wheels.
10-06-2018, 08:47 AM | #10 |
Drives: Love the one you're with Join Date: Sep 2009
I have stored hunders of cars over the years. If it's only over the winter months there is really no need to do anything outside of cleaning it, fill the fuel tank, make sure the tire pressure right and use a battery maintainer. I also change the oil when coming out of storage in case any condensation ended up in the crankcase. In saying this, my stuff stays inside in a conditiined enviroment too.
10-06-2018, 09:23 AM | #11 | |
Retired from Car mfrs....
Drives: 2LT RS/HR-V Join Date: May 2013
10-06-2018, 02:36 PM | #12 |
Drives: 2015commemorative vert 2SS Join Date: Oct 2013
Wow for the last 10 years I havent done all that much, with any of cars I have stored. Put it on a battery tender, and thats it. My garage is somewhat climate controlled. Never had any tires issues from sitting.
I didnt change the air pressure in the tires. I didnt change the oil I didnt fill the tank up with fuel. I always keep the car clean, and waxed, so thats nothing new. I dont put a cover on it
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded 2015 commemorative vert 2ss Last edited by sengli; 10-07-2018 at 08:28 AM. |
10-06-2018, 05:21 PM | #13 |
Drives: 2018 ZL1 1LE Join Date: Aug 2018
To those who use battery tenders, on the ZL1 1LE with battery in the trunk (not sure if non 1LE is located there), it's very difficult to get access to the negative terminal through the panel opening. Do you guys use the satellite terminals under the hood or clamp directly to the battery? I've always hooked directly to the battery, but I just can't get the clamp in the far back corner in the trunk.
Current stable:
2018 ZL1 1LE Arctic Blue 2018 MB C63S Coupe Selenite Gray Magno 2016 Tesla S White |
10-06-2018, 08:32 PM | #14 | |
2018 ZL1 1LE
Update: Here's the link to install. https://www.camaro6.com/forums/showthread.php?t=540177 Last edited by 1hprush; 10-07-2018 at 01:34 PM. |
