09-24-2018, 10:03 AM | #1 |
Livin' the Dream
Drives: '23 Charger GT, '23 Stingray Join Date: Mar 2013
Bolt-On Side Skirts
Are there any bolt-on side skirts that use existing bolts?
All I have found are one that require self-tapping screws and/or pop rivets.
If you spell Chuck Norris in Scrabble, you win. Forever. |
09-24-2018, 03:01 PM | #2 |
Drives: 2016 M6 2.0T Join Date: Nov 2016
Screws and 3M tape work great. Why do you feel you need bolts? Sounds impossible.
RS Package, HD Cooling Package, Brembo 6 Piston Front Brakes, SRP Racing Pedals, Soler Performance Throttle Controller, Dyno Tuned by Trifecta, Velossa Tech Ram Air, Mishimoto Intake, aFe Air Filter, Mishimoto Charge Pipes, ZZP 67mm Throttle Body, Trifecta T40 Stage 2 Turbo, JacFab Recirculation Valve, PTP Turbo Blanket, ZZP Catted Downpipe, Mishimoto Pro Cat-Back Quad Tip Exhaust, Mishimoto Catch Cans, Mishimoto Coolant Reservoir Tank, GM SEMA Grill, Ikon Motorsports Front Fascia Extension, Ikon Motorsports 1LE Spoiler, American Authority ZL1 Side Skirts, AMPP Quad Tip Rear Valance
09-25-2018, 10:52 AM | #3 |
Livin' the Dream
My Stingray had bolt-on' s that used the factory bolts underneath and 3M tape.
So it is possible.
If you spell Chuck Norris in Scrabble, you win. Forever. Last edited by Hulkamaniac; 09-25-2018 at 11:04 AM. |
09-26-2018, 11:10 AM | #4 |
Drives: 2016 Camaro SS, Garnet Red Join Date: May 2013
The oem ZL1 rockers can be installed using the existing clips. There are a couple of threads on here about the install.
