Roto-Fab
Old 08-08-2018, 11:07 AM   #1
ozzy1le
ozzy1le's Avatar
Drives: 2015 camaro 1le
Did cradle bushing inserts and trailing arms.
So I have a 15 camaro 1le with a btr cam, headers and intake. Had some wheel hop and decided to do the cradle bushing inserts and bmr trailing arms to minimize it. Now I think its actually worse. I get a loud bang when shifting gears like the whole cradle is moving but everything is tight. Any ideas? Should I have gone with the full bushings not the inserts?
ozzy1le is offline   Reply With Quote
Old 08-08-2018, 12:21 PM   #2
hou30guy
Drives: 2011 convertible 2ss/rs
How hard was the bushing install
Sent from my SM-N950U using Tapatalk
hou30guy is offline   Reply With Quote
Old 08-08-2018, 12:22 PM   #3
hou30guy
Do bmr lca too
Old 08-08-2018, 12:27 PM   #4
BandRcAMARO
Drives: 2010 Camaro 2SS/RS
sounds like something is loose
2010 Camaro 2SS/RS
BandRcAMARO is offline   Reply With Quote
Old 08-08-2018, 12:40 PM   #5
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
That's very strange indeed. The ZL1/1LE/Z28 cradle bushings are much better than the SS/V6 stuff to begin with, but inserts should still be an improvement. Stuff banging around definitely points to something still being loose - neither of those mods should cause banging.
Old 08-08-2018, 12:48 PM   #6
BMR Sales
BMR Sales's Avatar
Drives: Race Car
there are 3 items you need to get rid of Wheel Hop - Trailing Arms, Toe Rods & Cradle Bushings. to the OP, the Full Bushings are probably what you need
Old 08-08-2018, 12:52 PM   #7
hou30guy
Is there a write upon diy bushings
Old 08-08-2018, 12:58 PM   #8
SoFlaZ
SoFlaZ's Avatar
Drives: 2013 SS LS3
I'm looking to do them myself soon and I found this. The heat and jack method seems the easiest, post 9 is a video. Good info in this thread.
https://www.camaro5.com/forums/showt...t=cradle+torch
SoFlaZ is offline   Reply With Quote
Old 08-08-2018, 01:01 PM   #9
hou30guy
Thxs, regular ploy bushings or offset bushings
Old 08-08-2018, 02:05 PM   #10
Matt8892(2)
Drives: Black camaro 2ss 45th
Couple good videos on YouTube for the bushings. Did you remove the exhaust when you did your work?
Matt8892(2) is offline   Reply With Quote
Old 08-08-2018, 02:31 PM   #11
ozzy1le
ozzy1le's Avatar
The install wasnt too bad. I thought the 1le had upgraded toe rods.
Old 08-08-2018, 02:33 PM   #12
ozzy1le
ozzy1le's Avatar
As far as the bang goes I'm not sure what's causing it. Maybe a single hop on the tires. Just seems loose in the back now.
Old 08-08-2018, 03:12 PM   #13
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
They are. We share some ZL1 things and have upgraded bushings over a standard SS.
I did pfadt solid subframe bushings, pfadt trailing arms and pfadt toe links. Only time I get that one hard bang is on the strip doing a 1st to 2nd shift. It's slop in the driveline and shocking it getting back into power.
You might want to go over everything again because I would never describe the back end of my car as loose. Those mods made a huge improvement over stock.
CamaroDreams76 is offline   Reply With Quote
Old 08-08-2018, 03:16 PM   #14
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
I installed inserts many years ago and it did nothing but improve the stability. I rarely have wheel hop now.
Did you use new bolts? Are they torqued correctly?
2011 1SS/RS LS3 CGM
