AWE Tuning
Old 11-22-2015, 06:29 PM   #1
cuffnstuff1
Drives: Hearse
Skip shift and rev, match
So what does people think of the skip shift and the new rev match on the 6th camaro, I ordered mine with a manual transmission and Im worried about the skip shift going from 1st to 4th.
cuffnstuff1 is offline   Reply With Quote
Old 11-22-2015, 06:32 PM   #2
andrec10
Drives: 2016 Camaro 2SS 6SP/Suby Legacy 6
I had skip shift on my 99 C5 and had it programmed out when the car was tuned. Was not a fan! Hopefully there will be a way to program it out!
andrec10 is offline   Reply With Quote
Old 11-22-2015, 06:34 PM   #3
cuffnstuff1
Drives: Hearse
I heard the 6th gen has improved drastically with the skip shift, I know the 5th there is a module to install, I bought a manual to enjoy the feel and control if shifting and they take gears away, Damn. but I cant wait.
Old 11-22-2015, 06:50 PM   #4
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
If you don't like the skip shift, I can guarantee there will be a piggyback harness out to remove it. Some people hit it a lot, some don't. Depends on your driving style. I will be removing it regardless, always have in the past too.
I've driven a C7 with rev match, it's very cool. But, if it's not your style it can be turned off with a flick of one of the rev match paddles.
Old 11-22-2015, 06:58 PM   #5
mjwill25
Drives: 2016 Black 2 SS
The skip shift isn't an issue, all it is on the 2016's is a message on the dash that says to shift from 1st to 4th for better milage, it doesn't stop you going through the gears at all.
Also, the rev match is great and if it gets annoying, it is just a tap of the paddle to turn it off.
2016 2SS Black on Black, NPP, MRC with 6 speed, ARH Catted LT Headers, AWE Touring Exhaust, RotoFab CAI, Soler Performance TB and TC, GPI Ported LT2 IM, Pray Ported Heads, Pray Custom Grind Stage 2 Cam, DSC v2, BMR STB019H, Stance SF10 in Brushed Dual Gunmetal, Black Bowties, Black SEMA Grille, Smoked Tail Lights, Oracle Ghosted Side Markers
mjwill25 is offline   Reply With Quote
Old 11-22-2015, 07:04 PM   #6
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
Really? There should be a solenoid that blocks 2nd when skip shift is active. At least that's how it is on my 4th gen. Disabled for less than $1 by putting a resistor in the harness!
Old 11-22-2015, 07:06 PM   #7
cuffnstuff1
Drives: Hearse
Ok i thought it wont let you sift from 1st to 2nd at certain times it only allows you to shift to 4th, ok if thats the case then i am not too worried about it.
Old 11-22-2015, 07:13 PM   #8
mjwill25
If it does block you going from 1st to 2nd, I haven't found it yet. I have done a few hard launches, not as much as I want since I am just at about 100 miles so far, and it always just pops the message up but I can go into 2nd without an issue.
Old 11-22-2015, 07:19 PM   #9
paul84043
paul84043's Avatar
Drives: 2015 Camaro 2SS RS 1LE
If it still works the standard way, it's really freaking annoying.
paul84043 is offline   Reply With Quote
Old 11-22-2015, 08:46 PM   #10
BahamaTodd
BahamaTodd's Avatar
Drives: 08 Accord V6/M6 / 04 Canyon Z71
According to the manual its supposed to force you to 4th when the message comes on.
Maybe someone at GM slipped in some "cheat code". Shhh, no one tell the EPA...
BahamaTodd is offline   Reply With Quote
Old 11-22-2015, 08:56 PM   #11
cuffnstuff1
Drives: Hearse
what is the point of skip shifting? Is it to manage the RPM and gear ration for better performance or fuel economy or just o be a pain in the ass. when you do skip shift is the engine going to bog down and lower the RPM to prevent over rev. While waiting for mine I am going to go test drive one like Jeff Gordan give my salesman a ride.
Old 11-22-2015, 08:59 PM   #12
BahamaTodd
BahamaTodd's Avatar
It keeps the rpms low during easy acceleration for fuel economy.
Old 11-22-2015, 09:03 PM   #13
cuffnstuff1
Drives: Hearse
Thats stupid I dont by cars for fuel econmy If i did i would by a bicycle. I dont care abut fuel consumption.
However being that the manual transmission option does not allow AFM do we have to pay the extra Fuel tax, My dealer did not discuss that.
Old 11-22-2015, 09:14 PM   #14
BahamaTodd
BahamaTodd's Avatar
There is no gas guzzler tax on the Camaro. Its features like skip-shift which help to avoid the tax. Every little bit also helps with GM's overall CAFE rating so that they can continue to build cars like this.
