04-15-2015, 05:05 PM | #15 | |
Vrrrm.
Drives: 2011 2SS/RS LS3 Join Date: Jun 2013
You are stupid if you think i should put a 3mm spacer to fix my issue. The tire hits already lets just put a peice of metal between my rim and rotor so it sticks past the fender completely? Retard go home.
04-15-2015, 05:08 PM | #16 |
Vrrrm.
Thank you, you have renewed my faith in humanity
04-15-2015, 05:48 PM | #17 |
Vrrrm.
Boze helped me out, when measuring a wheel i guess you measure from lip to lip then deduct a inch? i measured mine to be 11outer lip, inner lip 10.5 so these are techincally a 10 wheel. Makes sense now.
Boze doesnt give offsets? just back space and i found this and called and zack verified it for me. Front wheels: 20x8.5, 5.75-inch BS, 255/45-20 tire Rear Wheels: 20x10, 6.875-inch BS, 285/40-20 tire Read more: http://www.superchevy.com/how-to/cam...#ixzz3XQ9TcX3l Follow us: @SuperChevy on Twitter | SuperChevyMag on Facebook
04-15-2015, 06:15 PM | #18 |
Drives: Chevys at the limit Join Date: Nov 2010
What offset are your wheels and where is it rubbing?
Best regards, Tyler 888-308-6007 |
04-15-2015, 06:38 PM | #19 |
Drives: 2010 Camaro LS-M6 67 Chevelle Wgn Join Date: May 2009
I don`t know how many miles you have on your car but have you checked your rear struts? If they are fine then maybe you might want to consider changing to a little stiffer strut before buying another set of tires.
04-15-2015, 07:25 PM | #20 |
Vrrrm.
I figured it out, thanks
04-15-2015, 07:33 PM | #21 | |
Vrrrm.
boze wont give there offsets out, lets just say they are not 35. The rear wheel is 10 inch (but measured 11 outer to outer lip) and they recommend a 285 out back, which makes sense. There offsets are built around that tire size not 315. Thanks though if you dont mind if i order new wheels whats it the absolute widest i can get can anyone make a 345 fit?
04-15-2015, 08:46 PM | #22 |
Bayou City Muscle Cars
Drives: 2013 2SS Dusk Edition Join Date: Jan 2013
had 315s on for over 2 years. never once rubbed. who speced the offset of your rear wheels?
the Nittos are very narrow tires any others brand 305s will rub just as bad if your offset is that screwed up.
Lethal Racing Stage V PER 418ci Forged LS3 530/520 SAE |
04-15-2015, 09:02 PM | #23 | |
Vrrrm.
10 inch wheel really is too skinny for a 315 anyway, so again i am allset i figured it out.
