04-27-2019, 01:15 AM | #1 |
Drives: 2019 SS A10 Join Date: Mar 2015
Question about undercarriage
So I was installing my splitter and wheels today and when I jacked the car up I noticed a dent underneath and I dont know what this part is called. I circled it on the picture. Is it supposed to be dented? Other side wasnt. Is there a part number for it?
Black 2019 SS A10, MBRP Exhuast, Soler performance Ported Throttlebody, Cold Air Inductions CAI, BMR equipped, Stance SFO7 on nitto NT555G2 tires, Limited Edition White Racing Seats, ZL1 1LE Splitter, Carbon Sideskirts, Gorilla Splitters areo kit, Next Gen Speed Diffuser, JWmotorsports LED side markers
04-27-2019, 02:18 AM | #2 |
Drives: 2017 2SS M6 Join Date: Jun 2013
no its not supposed to be dented. that if from someone putting a jack stand were they should not have. the pinch welds are the only part of the car that can support the weight of the car. it will be fine. but get some ZL1 Addons lift pads. they are the only way to lift the car without damage. https://zl1addons.com/collections/ca...-on-for-camaro. as far as putting the car on jack stands there is no place to put them. so get 4 of these too https://zl1addons.com/collections/ac...ton-floor-jack and 4 of these https://www.harborfreight.com/15-ton...ump-60569.html
04-27-2019, 02:31 AM | #3 |
Thank you! Can I replace it? Is the a part number for it?
04-27-2019, 02:43 AM | #4 |
yes its replaceable. i cant find the part number. ask https://www.thatgmpartsguy.com/contact-us
04-27-2019, 06:10 AM | #5 |
Luis, don’t worry about replacing the part as it is just slightly dented and on the underside of the car where no one can see. Spend the money on more mods for your Camaro! My advice..
04-27-2019, 07:41 PM | #6 |
Drives: 2017 ZL1, Arctic Blue, A10 Join Date: Jul 2017
07-01-2019, 03:46 PM | #7 |
Drives: 2019 ZL1 A10 in White Summit Join Date: Apr 2015
I have just checked under my new ZL1 that I have just picked up last wednesday and I see same kind of very small bend on each side almost symetrical.
I have never lifted my vehicle nor went to a dealer, I only have 400mi on the car. Probably dealer lifted there when they did their prep work.... |
07-01-2019, 03:55 PM | #8 |
Here is what it looks like,
Grease marks point to some sort of lift/jack Last edited by Ricard350; 07-01-2019 at 04:23 PM. |
07-01-2019, 05:12 PM | #9 |
Drives: 2015commemorative vert 2SS Join Date: Oct 2013
As warned many times before, I havent been to any dealer (4 so far) so far that has any idea how to properly lift a camaro. To them its just another car, and they lift it by any means they would normally use.
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded 2015 commemorative vert 2ss |
