BeckyD @ James Martin Chevy
Old 11-16-2018, 02:21 PM   #1
kaz1961
Drives: 2018 RS
Factory fill oil?
Read through a bunch of first oil change threads and cant find an answer. Does the factory fill our engines with straight dino, synthetic blend or full synthetic when new?
kaz1961 is offline   Reply With Quote
Old 11-16-2018, 02:59 PM   #2
Nsxmatt
Drives: 2017 Camaro
Owners manual says car comes with and uses dexos1 which is a synthetic blend.
Nsxmatt is offline   Reply With Quote
Old 11-16-2018, 03:48 PM   #3
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Dexos1 for I4 and V6, Dexos2 for V8.
An example of Dexos2 is Mobil1.
Old 11-16-2018, 04:41 PM   #4
thescreensavers
thescreensavers's Avatar
Drives: SW 1SS 1LE / Jeep XJ
Newer V8s 2019+ should be coming with the new M1 Dexos2 oil, older ones came with Dexos1 spec oil.
thescreensavers is offline   Reply With Quote
Old 11-16-2018, 08:34 PM   #5
wjones14
wjones14's Avatar
Drives: 2021 BMW M2 Competition
Dexos1 is not necessarily a synthetic blend. Mobil 1 5W-30 Full Synthetic has the green dexos1 label on the container:
https://www.walmart.com/ip/Mobil-1-5...-5-qt/17034372
2021 BMW M2 Competition 6MT
2011 Candy Lime Green Kawasaki Z1000 (1/4 mile - 10.38 @ 129.61 mph - stock)
Previous: 2018 Summit White 2SS 1LE; 2015 MINI Cooper F56 6MT; 2015 BMW M235i 6MT; 2003 MINI 5MT; 2005 Mustang GT 5MT
wjones14 is offline   Reply With Quote
Old 11-16-2018, 11:54 PM   #6
Bongos2U
Drives: Hopefully 6th gen Camaro
This is from the 2018 Camaro Owners manual:
Recommended Fluids, Lubricants, and Parts:
Engine oil meeting the dexos1 specification of the proper SAE viscosity grade. ACDelco dexos1 full synthetic is recommended.
Viscosity Grade: Use SAE 5W-30 viscosity grade engine oil.
Bongos2U is offline   Reply With Quote
Old 11-17-2018, 07:24 AM   #7
Rock-It Man
I wonder why the change.
My 2010 Gen5 came with Mobil1 and has a Mobil1 logo on the oil fill cap. Mobil1 is rated dexos2. In later years (not sure when), GM downgraded the Camaro V8 to dexos1. This seemed odd to me.
Now they are back to dexos2. What did they learn?
Old 11-17-2018, 07:38 AM   #8
Nsxmatt
Drives: 2017 Camaro
My owners manual on my 17 says blend.
Old 11-17-2018, 08:31 AM   #9
iPODFAN11
iPODFAN11's Avatar
Drives: 2019 Shock ZL1
Blend has been dropped by GM and is no longer produced by them, and replaced with the full synthetic spec.
Any Dexos1 spec oil for 2018 (all engines) and 2019-prior T4 and V6.
2019 V8 are Dexos2 spec oils.
From Super Chevy mag, April 2002: "Most of the weekend Settlemeire was meeting and greeting and quickly became known as simply "The Camaro Dude" (note, even his initials are SS)."
we're certainly looking at it -- but right now, the emphasis MUST be on getting the Camaro V6 and SS out -- and having it exceed your expectations....
Once that's done....................
iPODFAN11 is offline   Reply With Quote
Old 11-17-2018, 08:32 AM   #10
wjones14
wjones14's Avatar
Matt, can you quote what it says in your manual? Not doubting you. I see several cases of contradicting information in my 2018 manuals, so I wouldn't be surprised at all if the 2017 manual actually recommended the blend.
But just to clarify one thing - dexos1 does not specify full synthetic or blend. You can find the green dexos1 symbol on both synthetic blend and full synthetic oils. The dexos1 designation is the requirement. It could be the blend or full synthetic (for 2018). The 2018 manual does not say full synthetic is required. It says it is recommended on page 339 of the 2018 owner's manual. @Bongos2U posted the exact text above.
This blend would actually meet the requirement, but not the recommendation for 2018:
https://www.walmart.com/ip/Pennzoil-...iner/155248421
Back the OP's question, who knows what the factory fill is? My Blackstone Labs analysis report after changing the factory fill said the viscosity was in the 5W-20 range, but no mention of synthetic versus blend.
Old 11-17-2018, 08:43 AM   #11
wjones14
wjones14's Avatar
Mobil 1 is not always dexos1. I was just in the oil aisle at Walmart the other night, and the blue dexos2 label was few and far between. All the Mobil 1 oil either had the green dexos1 label, or no dexos label at all. Valvoline 5W-40 MST full synthetic had the blue dexos2 label - this is one of the oils specified for Track usage in the 2018 owner's manual. The other dexos2 oil specified in the 2018 manual for Track usage is Mobil 1 ESP Formula M 5W-40 (hard to find in the U.S.). The Track recommendation (requirement?) is different than the daily driver recommendation/requirement.
But, as others have pointed out, each year seems to be different, even though the cars use the same engine. Very odd and confusing.
Old 11-17-2018, 10:50 AM   #12
Nsxmatt
Drives: 2017 Camaro
Sure thing. Here is the fluids for the 2017’s from my Chevy app owners manual.
Old 11-17-2018, 12:09 PM   #13
Rock-It Man
I looked again, and you're right: regular Mobil1 has a dexos1 rating.
Old 11-17-2018, 08:30 PM   #14
wjones14
wjones14's Avatar
That's unreal! Factory fill may well have been synthetic blend in 2017...
So what do you use in your 2017 LT1?
