03-27-2021, 01:31 PM | #1 |
Drives: 2018 Camaro SS 1LE Join Date: Oct 2019
Advice needed. Big screw up
Tightening my oil cap with a wrench and this happened. Bolt broke off. Any ideas on how to free the part stuck in the hole?
03-27-2021, 01:36 PM | #2 |
If you’re asking here it’s too much for you. Get to a good mechanic.
'16 Camaro 1SS
03-27-2021, 01:41 PM | #3 | |
Drives: 2016 2SS Convertible Join Date: Oct 2017
If so, center punch it as close to the center of the broken piece as possible, then use a reverse drill bit to drill a hole into it. Do not use standard drill bit! With any luck, the broken piece will back right out as you're drilling the hole. If not, you many need to use a broken bolt extractor after you've drilled the hole into the center or the broken piece. Good luck with it. --KLG--
2016 2SS Convertible; SIM; Black & Ceramic White interior; M6; NPP; DD LED side marker lamps & back-up lamps; LED trunk lamps, license plate lamps & front T/S lamps; 3rd brake light pulser; Skip-shift eliminator; Borla s-type non-npp axle backs; Weather-Tech floor mats, trunk mat, rear license plate frame/cover; GM fuel door; ZL1addons rock guards; Removed fender badges, front & rear SS badges; JLT CAI, tune, oil separator; RP Synchromax in transmission; RP MaxGear in rear differential; GM Lowering Suspension Upgrade; Dimple oil filter magnets & magnetic oil drain plug; 3M Ceramic window tint.
03-27-2021, 01:45 PM | #4 |
Oh Jesus i got it. That little metal piece that’s sticking off the plug was just big enough for me to spin it out with an Allen key. Huge relief thanks for the help
03-27-2021, 02:21 PM | #5 |
Drives: 2021 2SS Join Date: Jul 2020
Glad you got it out.
I am honestly shocked the bolt broke in half before you just destroyed all the threads in the pan, being aluminum and all. The torque is quite low on that bolt (18 ft-lbs I believe), you must have been really going at it or the bolt was defective in some way. |
03-27-2021, 02:27 PM | #6 | |
03-27-2021, 03:15 PM | #7 |
Drives: 18 ZL1 - M6 Join Date: Mar 2019
I'm glad to see that you got it out. I cringed when I saw the picture. Chalk this up to a lucky day.. Now, go buy a lotto ticket. Maybe you're good for two lucky miracles today..
Take care... |
03-27-2021, 05:34 PM | #8 |
Drives: '21 Wild Cherry ZL1 Join Date: Aug 2018
Never had that happen in hundreds of oiled changes.
03-27-2021, 06:19 PM | #9 |
Drives: 2018 ZLE Join Date: Feb 2018
Damn thank goodness.
03-29-2021, 06:33 AM | #10 |
Glad you got it out, but you need to get your arm recalibrated LOLZ.
03-29-2021, 06:54 AM | #11 |
Were you using a torque wrench?
2023 Camaro ZL1 Vert TR-6060 Sharkskin "Sharky"
Firecracker Red Wrangler Willys, 3.6L eTorque, 850RE 8 speed automatic, 25W Willys package, Technology Group, Convenience Group (aka $600 garage door opener), Cold weather Group, Trailer Tow and HD electric group with AUX switches, 3 piece black freedom top. |
03-29-2021, 07:02 AM | #12 |
Drives: 2018 ZL1 1LE Join Date: Mar 2018
Same here. of all the cars i've owned in 25 years the ones with drain bolts that were over torqued always end up stripping the threads then leak. I've never seen one actually have a bolt break.
2018 Chevy Camaro ZL1-1LE
2015 Silverado 2500HD 1999 Jeep Cherokee Sport 1998 Dodge Viper GTS 1972 Pontiac GTO 1963 Chevy C10 short bed, T5, 350, lowered |
03-29-2021, 08:13 AM | #13 |
雪の玉
Drives: '22 Z71 RST Silverado Join Date: Feb 2011
Whew...glad you got it removed....somebody doesn't know their own strength, lol
03-29-2021, 11:42 AM | #14 |
Drives: LT1 Ordering Join Date: Mar 2021
Good job getting it out.
Air impacts and electric drills are for taking bolts OFF. Never use these to put them on unless the owners manual calls for it. Like others have said, you may have bent the threads. Get a new drain bolt and crush washer check it every day so see if its slightly leaking. If so so you just need a new oil pan, dirt job but very easy if u get the gasket and don't over torque any bolts lol. |
