03-12-2024, 03:10 PM | #309 | |
1000hp is NEVER Enough!
1,000hp IS NEVER ENOUGH!!!
03-12-2024, 04:59 PM | #310 |
03-12-2024, 08:22 PM | #311 |
Congratulations and very nice job! Your car sounds awesome!!!
03-13-2024, 01:41 AM | #312 |
Thank you sir.
03-13-2024, 05:01 AM | #313 |
Sounds healthy to say the least. Nice job!!!
03-13-2024, 08:53 AM | #314 |
03-13-2024, 08:58 AM | #315 |
Sounds awesome Joe!
03-13-2024, 09:00 AM | #316 |
03-19-2024, 01:54 AM | #317 |
Just an update but it runs awesome! I'm so happy. No more oil leaks or lifter tapping. My tuner is really good and has been slowly increasing timing. With every little bit of timing it just gets faster and faster. I just stated to go wot a few days ago after a decent break in period. Like I said I'm just so happy everything turned out so good!
03-19-2024, 03:44 AM | #318 |
Glad to hear it, always a great feeling when things go right.
03-19-2024, 03:45 AM | #319 |
Yes it is. Thanks Joe.
03-28-2024, 06:17 PM | #320 |
So I changed the oil with the break in oil after 20 minutes and then after 250 miles with the break in oil to conventional oil. Now I have 460 miles on the conventional oil and am wondering when I should change it again. What are your guy's opinions?
03-28-2024, 06:40 PM | #321 |
I would probably dump it at the 1,000 mile total mark.
03-29-2024, 05:15 AM | #322 |
Thanks Joe!
