07-18-2020, 09:52 AM | #225 |
Drives: 2023 Chevrolet Camaro 2SS 1LE Join Date: Jan 2020
If Chevy ever drops the LT2 in a Camaro, you can sign me up as a customer for it. I don't care what they call it. If they call it a Z/28 I'm fine with it and I'm fine with it not being the top Camaro. My preference would be LT2, SS 1LE body/similar setup (ZLE is just too extreme for the street imho) and some suspension tweaks to assist with the extra power. Make it a good drivers car on the street, then focus on the track. The majority of people buying these cars are not tracking them and a 6th gen SS 1LE with an LT1 is already good enough on track, the 40 extra horsepower would just be icing on the cake. I think this version of a Camaro would be a great swan song for the Camaro/6th gen.
07-18-2020, 05:35 PM | #226 | |
Drives: SS 6 speed of course Join Date: Jan 2016
07-19-2020, 08:29 AM | #227 |
Drives: like an old lady Join Date: Jun 2012
they only problem with putting an LT2 in a camaro is it wouldn't be an LT2, it would be a variant because the *real LT2 won't fit in anything but a vette. if 40 crank hp excites you that much, cai, headers and a tune will get at least much that for you.
the LT2 appeal stops with the camaro. won't be dry sump, won't have the good intake manifold and won't have the good exhaust. the LT2 uses the exact same rotating assy as the LT1. it appears the cyl heads are almost identical, if not, as well. different camshaft, that honestly would not work (*as advertised in a vette) in a camaro because of the intake/exhaust restrictions. so basically an LT2 camaro won't happen and if it ever could it would be an LT1.5 with performance easily surpassed by minor bolt on LT1 cars.
2016+ camaro: everyone’s first car
07-19-2020, 11:54 AM | #228 | |
07-19-2020, 02:23 PM | #229 | |
Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
Doesn't mean I will buy one, but IMO it will set itself to be different from other Camaros to be unique. Sent from toaster or something
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
07-19-2020, 02:32 PM | #230 | |
07-19-2020, 07:42 PM | #231 |
Drives: Chevy Camaro Join Date: Nov 2019
Agree. Not to mention the cost and how the heck do you suppose this FPC mess would slide into a Camaro engine bay? No thanks.
07-19-2020, 08:54 PM | #232 |
Next time you set past a C7, look at the hood and you realize there is a V8 under there. Walk past a Mustang and realize that under that hood and the complete engine bay is filled with an engine... no thanks.
07-20-2020, 01:52 AM | #233 |
it would be difficult to hold a DI 427 to only 530 crank. at bare minimum it would make 575 assuming gm didn't use a left over small bore cyl head and cam profile. i don't think the hp:cid math works directly as displacement grows. a factory DI 427 would require a lot of work on the cyl head and intake manifold front. both of which are weak on the LT1.
07-20-2020, 08:33 AM | #234 | |
Drives: 1SS, A8, MRC, NPP, Blade Spoiler Join Date: Jun 2010
AND, since the Gen6 Camaro program has been extended, there is time for the Z06 to come out in MY22 and a Z/28 in MY23. As for fit, going to a lower displacement means it would probably fit, but we can't be sure at this point. This would help keep the Z06 and Z/28 true to their N/A history. Now, as for the oldman's idea of developing a new 7.0L engine would mean developing a whole new engine for just the Camaro (as I don't see this engine going into a Corvette). While possible, I think this idea is extremely unlikely for this reason alone. Personnaly, I LOVE the idea, but I just don't see it happening. Even a 5.5L FPC Z/28 is a long shot. If there is one more big Hi-Po Gen6 Camaro, I think they will just put the LT5 in the ZL1 and call it a day (which I would love to see as well). But, they should stick to the ZL1 name if they do... |
07-20-2020, 10:53 AM | #235 | ||
Drives: 21 Bronco Join Date: Jun 2012
I do believe in a head to head match up done by one of the mags the Z/28 was faster around the track and I believe its faster around Laguna Seca jsut looking at old BDC data. Quote:
Obviously it would outperform the SS 1LE, but how does it stack up performance wise/price wise to the ZL1. That is where I see the biggest hold up. Also I don't think we will ever see another 7.0L performance engine. IIRC that was the route they originally wanted to go for the C7Z06. They could get the power but couldn't pass cold start emissions so they went boost. Or at least that was the rumor floating around |
07-20-2020, 01:14 PM | #236 | |
07-20-2020, 01:21 PM | #237 | |
But a DOHC is a completely new engine for the Camaro and there is NO cost justification for it as the chassis is already traction limited. Plus I'm still not buying this smaller size DOHC engine that "fits" in the Camaro. Ford had decades of turkey SOHC and DOHC engine designs and arguably the latest 5.0 is not any "better" vs the LT1 / LT2 / LT5 / LT5. Ford (which should be no surprise) did what Yamaha has been doing for 50 years now, raise the intake port to make power NA and that means the engine gets EVEN BIGGER. So if GM goes with a "small" external dimension 5.5 DOHC it will have a extremely compromised port design and that means it will ONLY be good under FI where boost makes up for port flow (still got 4 valves and variable valves timing). But is makes for a shizznet NA engine.... just ask Ford going back to what 1994 ish??? Just about the time they contracted with Yamaha to build their SHO V6 and V8s, heck they could have hired me for pennies on the tens of thousands of dollars, I've been porting and racing Yamaha heads since the Toyota 2TG and 3TG engines (early 70s). You want a DOHC to flow? raise the port.... not "easy" on a V engine, especially if you now have a hot valley and the intake is now down by the fenderwells. Look at the new GM hot valley V engines, the intake manifold looks like an exhaust manifold (no surprise there) it must breath like an two pack a day 90 year old great grand pa, the engine has two turbos and in fact the smaller intake volume is not a bug it is a feature as the velocity hence response is REALLY good. But to pretend that you going to get this thing to breath like a Ferrari just because of the DOHC moniker belies a lack of engineering appreciation. https://gmauthority.com/blog/2018/03...lly-announced/ What part of a 5.0 Mustang's completely filled engine compartment don't you get????? I mean really? It has been going on 3 decades now that Ford's answer is UNWORKABLE given the Camaro and upto the C7's hood lines. Here a Ford: (caution GM folks as this may burn your eyes as well as dull your wits an no A/C and no warranty and a hideous hood bulge. )
07-20-2020, 01:55 PM | #238 | |
