10-05-2020, 01:29 AM | #1 |
Drives: 2018 Chevy Camaro Join Date: Aug 2020
Quad diffuser install
I just installed the gloss back quad tip diffuser I got from Next Gen Speed. When removing the stock diffuser I got the 5 metal retainers off using a flathead screwdriver but when I put the new one one, I couldn't find a way to put them back on (mainly the center 3). There's not much space to work with since I did not take the bumper off. Any one else have this problem. I dont think itll be an issue just wanted to double check to see if I should be concerned. Only other issue is there's slight gaps on the sides of the diffuser but you cant tell unless your are really close.
10-05-2020, 06:50 AM | #2 | |
TD
Drives: 2017 2SS, 2014 Mercedes C300 Join Date: Feb 2020
10-05-2020, 07:09 AM | #3 |
Drives: GMC Sierra AT4 Join Date: Jul 2013
I think the best way to do it is by removing the bumper. I haven't done a diffuser swap on a 6th gen but I have on a 5th gen and it was a total pain without removing the bumper when removing the bumper would have made it a lot easier.
I don't think the metal clips will matter as long as the plastic tabs are secure into the bumper. Other thing is with those metal retainers is with the teeth that are on them they tend to bend when you remove them to the point that they are near impossible to re-install as is and have to be bent back into proper position.
2020 GMC Sierra AT4 6.2L
WTB - 2010 Camaro 1SS or 2SS, Aqua Blue Metallic, A6 |
diffuser, fitment, nextgen, quad tip diffuser, retainer |
