Old 06-12-2020, 02:52 AM   #1
Alvin
Alvin's Avatar
Drives: 2017 Camaro 1SS
Wheels doesn’t fit
https://imgur.com/ZxYG1ae
Recently bought a set of Curva C300, they looks great and the price is attractive.
Front:20x9.5 30mm offset
Rear:20x10.5 30mm offset
Also bought a set of Nitto NT555
Front:265/35r20
Rear:285/35r20
Front was about 2mm close to the lower part of my suspension when my car was lifted up, rear was about 5mm close the inlet fender.
Alvin is offline   Reply With Quote
Old 06-12-2020, 04:15 AM   #2
Yellow Beast
TD
Yellow Beast's Avatar
Drives: 2017 2SS, 2014 Mercedes C300
5mm spacers
Yellow Beast is offline   Reply With Quote
Old 06-12-2020, 07:10 AM   #3
JT58
Drives: Former 2016 Camaro 1LT
It sounds like they are barely interfering. I have 20 X 10 square with 27535R20 tires, wheels machined to a 28 MM offset and they clear. Tires poke out just a tad though.
Easiest solution is 5 MM spacers. You might even get by with 3 MM Spacers.
2006 C6 Corvette Manual, 2019 Silverado, 1997 Jeep Wrangler
JT58 is offline   Reply With Quote
Old 06-12-2020, 08:31 AM   #4
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
I found that the clearance changes a bit between being on the lift vs. weight on wheels. You have to check it sitting on the ground. Also check strut clearance with the top of the front tires.
Mark114 is offline   Reply With Quote
Old 06-12-2020, 01:37 PM   #5
Alvin
Alvin's Avatar
Thanks for all the comments, I just figured out the Mavis Tire Shop ( 2507 Park Road , Charlotte) put my rear tires on the front rims and front tires on my rear rims. Yes, it’s unbelievable, they did not program my new tire sensors and didn’t balance my tires either. I went to another shop and they fixed the all the mistakes. My front tires are like 1mm close to the lower struts. I hope that’s fine.
Old 06-12-2020, 01:46 PM   #6
Alvin
Alvin's Avatar
Now I’m having another issue, my car vibrates/wobble after 50mph. Seems like tire balanced incorrectly. Hopefully it’s not bent rims. I’m just having a really bad day.
Old 06-12-2020, 01:56 PM   #7
CrazyCatGuy
I'm the cats pajamas baby
Drives: 2018 Camaro SS 1LE
Take it back to the shop that re-did the other shop's mistakes and tell them to check the balance.
CrazyCatGuy is offline   Reply With Quote
fitment, rims, rubbing, tires, wheels
