Old 03-24-2019, 11:45 AM   #1
19Shadow1LE
Drives: 2019 Camaro 1SS 1LE - Shadow Gray
Windows Down = Unbearable Wind Buffeting/Percussion
Does anyone else experience extreme wind buffeting with both windows down at ~40+ mph? It's even worse with one window down, but I never do that.
I have experienced this effect in sedans with only the back windows down, but it's easily resolved by lowering the front windows.
I've owned a 1997 Camaro, 2000 Corvette, and 2003 Cobra, and have NEVER experienced wind buffeting with the windows down.
Are there any good solutions to this problem? I don't have a sunroof to open so that's not an option.
19Shadow1LE is offline   Reply With Quote
Old 03-24-2019, 11:50 AM   #2
DaveC113
DaveC113's Avatar
Drives: 2018 Camaro 1SS 1LE
I don't get buffeting but am annoyed by the way the seatbelts flap around at highway speeds. I've been considering making some sort of small wind deflector which would stop this and maybe help smooth things out a bit.
DaveC113 is offline   Reply With Quote
Old 03-24-2019, 12:10 PM   #3
HighIron
Drives: 2024 2SS Summit White
Yes, my observations pretty much mirror yours. The buffeting being annoying enough to outweigh any fresh air feeling.
It's not a big issue for me since the range of outside air temp that favors open windows is pretty small for me, and in the spring, I don't want the heavy pollen inundating my interior ( and me ). Most of the time I run windows shut with either A/C, heat, or fan.
The other issue is sound. One would think this seems illogical, but for whatever reason the exhaust sound ( NPP valves open ) has a nicer tone from inside the car with the windows shut. Throatier, somehow.
HighIron is offline   Reply With Quote
Old 03-24-2019, 12:10 PM   #4
DenverTaco07
DenverTaco07's Avatar
Drives: 2017 SS 1LE, 2017 Volt, 2013 Pilot
one window down, yes, but with both down that does seem weird. I did see some sort of TSB summary stating something about the buffeting, but would need a subscription to see the details.
NHTSA ID: 10114041
TSB ID: 17-NA-140
This technical bulletin provides repair information to correct a customer concern of a wind or buffeting noise that is heard in the vehicle cabin while driving with one window lowered
looks like for only one window down...
2017 SS 1LE | HBM | Vortech V3-Si supercharger (620RWHP and 575ft lbs) | PDR | Black Bowties | Illuminated Front Black Bowtie | Illuminated Door Sills | Smoked Tails | vented seats mod
DenverTaco07 is offline   Reply With Quote
Old 03-24-2019, 12:42 PM   #5
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Yes with my 2010 SS and my 2016 SS. Haven’t run with windows down in my Z but I’m sure it will do it too.
LT4Greg is offline   Reply With Quote
Old 03-24-2019, 02:23 PM   #6
Gasoline_Farts
Drives: 19 SS 1LE
It’s worse with the back seat down.
Also if you leave both windows just a few inches up, it stops
Gasoline_Farts is offline   Reply With Quote
Old 03-24-2019, 03:46 PM   #7
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
Silverado does it too. Sounds like your under a helicopter.
Old 03-24-2019, 04:33 PM   #8
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
I agree. I never drive on the highway with my windows open in my '17 SS due to noise / buffeting. I often did in my '00 Z28, even with T-Tops out and the noise / buffeting was much better in that car. Must be due to aerodynamic characteristics of each car.
Old 03-25-2019, 08:25 AM   #9
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
I drive with my windows down all the time at all speeds from 0 to 90. I only get buffeting if one window is up or they are both partially up, which is almost never the case.
Otherwise it is fine. Maybe the seat position and thus where your head is makes a big difference.
cellsafemode is offline   Reply With Quote
Old 03-25-2019, 08:43 AM   #10
CoolbreezeNJ
Drives: '18 Hotwheels 2SS
When one window is down I hear it but when I drop the 2nd window it was gone. My guess is that it is the headliner in the rear. It is not held down by anything hence I thought it was flapping in the breeze.
Should I put double sided tape in it or is my headliner either screwed or like everybody elses.
CoolbreezeNJ is offline   Reply With Quote
Old 03-25-2019, 08:46 AM   #11
Karma81
Karma81's Avatar
Drives: 2016 Camaro 2SS
Seems to go away when I open my Sunroof.
Karma81 is offline   Reply With Quote
Old 03-25-2019, 09:31 AM   #12
geaux_tigerss
geaux_tigerss's Avatar
Drives: 2019 GMC Sierra 1500 AT4
I ride with my windows down all of the time. Pretty much daily on my evening commute. I don't have buffeting like you are describing. On a side, note, this was an interesting find - particularly the top comment.
https://www.reddit.com/r/askscience/...e_window_down/
Summit White
6" Lift, 37x13.50R24's
geaux_tigerss is offline   Reply With Quote
Old 03-25-2019, 09:36 AM   #13
CoolbreezeNJ
NHTSA ID: 10114041
TSB ID: 17-NA-140
So where is the write up for this TSB??
Old 03-25-2019, 10:09 AM   #14
DenverTaco07
https://www.alldatadiy.com/
You would have to subscribe to get full access.
