05-30-2016, 07:14 AM | #1 |
Drives: 20 1LE 2SS M6 Rally Green Join Date: Mar 2014
Rear Differential Fluid Spec has changed
I noticed the second printing of the Camaro owners manual now calls for fluid 88900401 with limited slip additive 88900330.
The first printing called for fluid 88862624 only. A deliberate change was made so I assume they are not equivalent. My 4/19/16 build came with the second printing http://www.chevrolet.com/content/dam...ers-manual.pdf
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.” Ronald Reagan - |
05-30-2016, 11:08 AM | #2 |
Interesting. Now, is the rear end fluid something that should be changed within the first 5k miles or so?
'16 Camaro 1SS
05-30-2016, 02:00 PM | #3 |
Drives: 2016 1SS Join Date: Jan 2016
Also makes me wonder how many bottles of the additive should we use?
1SS, Black, Black Wheels, A8, MRC, NPP
05-30-2016, 02:06 PM | #4 | |
I change oil, transmission and differential after the 1,500 mile break in to ensure there isn't any assembly crap in the system. I found this chuck stuck to the plug magnet when I changed my ZL1 at 1,500 miles.
05-30-2016, 02:19 PM | #5 | |
I use a fluid pump so some fluid will be lost ($7 on Amazon). Pump third quart of fluid into axle. Then squeeze the bottle of additive in and top off. Go drive figure 8 pattern to mix it up.
05-31-2016, 01:21 PM | #6 | |
Drives: 2015 Tiger XCX,2016 Camaro 1SS,LBZ! Join Date: Sep 2015
05-22-2017, 07:19 AM | #7 |
Drives: 02 Camaro SS 6M / 11 GMC Sierra Join Date: Mar 2017
I ordered some fluid from the GM dealership that I bought my car from here in Canada and they said nothing about adding the limited slip fluid. They told me that mine takes 1.1 liters so I ordered two bottles it's good I came across this thread I'm going to have to get the new order me some of the limited slip fluid. I'm going to do it when I hit 1500 kilometers. Planning on doing the first oil change before a thousand kilometers. Has anybody else done the rear end on a V6 manual transmission yet? Anything out of the ordinary to watch out for or is it pretty standard lol.
05-25-2017, 01:10 AM | #8 |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
DO NOT ADD friction modifier to the GM fluid.
The revised part includes the friction modifier. It's printed right on the bottle.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
05-25-2017, 11:09 AM | #9 |
Camaros Of Northwest Ohio
The spec change is probably due to the rear end groan that many of us have. Read more about it here:
http://www.camaro6.com/forums/showthread.php?t=440272 First attempt at a fix is to do a couple of flushes with the new fluid that includes the friction modifier.
2023 2SS 1LE Red Hot
2016 2SS Black / Black & Arenaline Red (sold) 2023 GMC Canyon Denali 2013 2SS / RS - AGM / Jet Black (sold) 1970 1/2 Z/28 Classic Copper / Tan (sold many years ago) |
07-09-2017, 02:54 PM | #10 | |
Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
The TSB from this post also indicates 88862624 is correct for 2016-2017. http://www.camaro6.com/forums/showpo...&postcount=601 For reference, here's the 2018 owner's manual: https://my.chevrolet.com/content/dam...ers-manual.pdf
Best 1/4 Mile: 12.24 @ 115.9 mph Last edited by vtirocz; 07-09-2017 at 03:05 PM. |
07-09-2017, 03:27 PM | #11 |
Drives: 2016 Camaro 2SS Join Date: Apr 2017
I have a 2016 SS and my manual says to use the 88900401 with limited slip additive 88900330. I did NOT go that way. I went with 88862624 and the groan is gone.
2016 2SS, MRC, NPP, A8. Procharger P-1X,Stage II,std bypass, 3.9, Alky Meth - 10.84 @129 - DA+2000
New Mods - GPI drop ins, Kooks 2", LT4 fueling, Cam, Circle D Converter, 3.5 pulley & dual nozzle meth. |
07-15-2017, 07:26 AM | #12 |
Drives: 17' 1SS 1LE GBA-Black Join Date: Mar 2017
Anyone try this stuff?
BG is supposed to be top notch material, especially for such LSD and other gear applications and some rumors say that the AC Delco stuff is actually made by BG ? Anyone have a way to confirm this? Have a look: https://www.bgprod.com/catalog/drive.../#bg-product-1 Another option, is to get the LS/D concentrate MGC separately and mix with P/N 750 https://www.bgprod.com/catalog/drive.../#bg-product-7 + This: https://www.bgprod.com/catalog/drive.../#bg-product-6 |
07-16-2017, 02:02 PM | #13 |
Drives: Red hot ZL1 A10 2017 Join Date: Nov 2016
I changed mine at 1100 on my A10.
Regret not to have it done at 500.... A lot of metallic shit on the magnetic plug, and a dark fluid!!!!! Do it! But, I've noticed something different after.... Performance page / trans fluid temperature : I think but not for sure it was between 100-150F before rear diff change (Don't remember if I checked that on my 2ss fifty last year or on my ZL1 few months ago), And on the way back home with the new fluid, the temp stabilized almost at 200F ???? Have you seen that also? Is it normal? Thanks |
07-16-2017, 03:46 PM | #14 | |
Drives: 16' 2SS M6 Join Date: Feb 2010
