Old 05-04-2014, 04:24 PM   #1
2011BlackL99
Drives: 2011 black L99 camaro
275/40/20 on front stock rims?
is it possible to put 275/40/20 tires on the front rims?
2011BlackL99 is offline   Reply With Quote
Old 05-04-2014, 06:26 PM   #2
i2disturbedSS
i2disturbedSS's Avatar
Drives: 2010 SS L99 IOM
Yes it's possible - but not a good idea for safety reasons. Get another 9in rim.
369rwhp/392rwtq
"Spending money I don't have, to buy parts I don't need, to impress people I don't know!" -Jenkins
i2disturbedSS is offline   Reply With Quote
Old 05-04-2014, 06:40 PM   #3
omgitsmikeyC
Drives: 2014 CTS-V- totalled/ 45TH ss- SOLD
Possible, yes. But the recommended top size is 265 on the 8.5" rim. Otherwise could over stretch the tire, causing premature wear, a blowout, or the tire separating.
2014 CTS-V... with some go-fast bits coming
omgitsmikeyC is offline   Reply With Quote
Old 05-04-2014, 06:43 PM   #4
Jamie Mac
NCM-WINR
Jamie Mac's Avatar
Drives: 2010 SS/RS IOM 2014 2LT Stingray
I've seen it. Looks stupid the way the tire fits the rim. Listen to the guys above and get the wider wheels
also drives a heavily modified Jeep Wrangler. It has LED headlights and wheel weights blacked out with Plasti Dip. It's Baller.
Jamie Mac is offline   Reply With Quote
Old 05-04-2014, 06:46 PM   #5
MYDLIFECRISIS
MYDLIFECRISIS's Avatar
Drives: '12SS/2SS/45TH-'06 2500HD/Silverado
My opinion, don't put the rear size on the front 8" rim, get two more 9" rims.
2012 Camaro SS 2SS 45TH Anniversary Edition
MYDLIFECRISIS is offline   Reply With Quote
Old 05-04-2014, 06:56 PM   #6
95birdible
95birdible's Avatar
Drives: 2012 1SS Camaro Convertible
Is it possible to put the 20's on the front on the back? I am looking to have the same size all around so I can actually rotate the tires and have a spare. Any help would be appreciated. Car is a 2012 1SS Vert
2012 1SS Crystal Red Convertible
"Cherry Bomb"
Winner of the #NameThatCamaro Spring Special Edition
"Green Flash"
95birdible is offline   Reply With Quote
Old 05-04-2014, 07:08 PM   #7
CHMSC
ROAD COURSE JUNKIE
CHMSC's Avatar
Drives: 2012 SS/RS LS3
You mean rear wheels on the front? Yes works fine. I have ran that setup with 275/35/20 PSS for over a year.
CHMSC is offline   Reply With Quote
Old 05-04-2014, 07:13 PM   #8
Jcm
Drives: 2011 ss
Yes the fronts will work on the back..the stock front tires are actually slightly larger dia. Than the rear tires..but the wider rear wheels look much better all around..
Jcm is offline   Reply With Quote
Old 05-04-2014, 07:20 PM   #9
95birdible
95birdible's Avatar
That's good to hear. I like the wide rears but would like to be able to rotate at least every season when it comes out of storage.
"Cherry Bomb"
"Green Flash"
Old 05-04-2014, 10:41 PM   #10
caverman
caverman's Avatar
Drives: '69 SS Convertible
I've been running a set of rears (20x9 w/275) on all 4 corners for probably 2 years now without any issues. I didn't it mostly so I can rotate to get a little more life out of them.
-2010 Camaro 2SS | M6 | VR w/White Stripes | 1 3/4" KOOKS - 3" Magnaflow | LPE 3.91 gears | ADM tuned | Halltech w/ADM Scoop | Spohn/BMR Trailing Arm/Toe Rod | BC Coilovers| Pedders FE4 ZL1 swaybars | Cradle/Diff/Radius Rod bushings | VMax TB | Morimoto Projectors | MGW shifter | Red Calipers
Build Journal
caverman is offline   Reply With Quote
